73-87 Chevy _ GMC Trucks => Engine/Drivetrain => LT/LS Swaps => Topic started by: 85c10shortbed on March 31, 2015, 10:55:12 PM
I have a 1985 c10 short bed I purchased a 1994 Camaro lt1 already have wiring harness built was wondering what all troubles will I have or is it a simple swap
i know you said its a lt1 but we do have a LS swap board
http://forum.73-87chevytrucks.com/smforum/index.php?board=46.0
should be able to get an ideal from there
also you can use the search for lt1 and it will help you also
http://forum.73-87chevytrucks.com/smforum/index.php?topic=24012.msg201189#msg201189
EVEN BETTER
http://www.hotrodlane.cc/PDFFILES/83chevyLT1install.pdf
I thought about going with a 5.3 LS but couldn't pass up the deal
Since it is basically a SBC it will drop right in. Wiring will be the only complication. Are you going to use the electronic shifted trans?
im going to use a street fighter 700r transmission I was worried about the reverse cooling system on the heads
The cooling direction won't really matter in the grand scheme of things. If the motor was in front of an auto you may need the ECM programmed.
yeah I have done already done that I was wondering if my stock radiator would work
Yes stock radiator should work fine unless it is just a 2 row..
thank u I appreciate it
