Author Topic: Can't get brakes bled  (Read 3698 times)
Offline 1981lt1
Re: Can't get brakes bled
« Reply #15 on: January 16, 2022, 07:49:45 PM »
...There isn't an adjuster hole in the backing plate so this is as good as I think I can get them...
Are there knockout windows in the drums?
No.
Offline JohnnyPopper
  • Old Goof
« Reply #16 on: January 16, 2022, 08:50:12 PM »
Well...Poop!
Can you make some?
1980 C-10 under construction
Offline 1981lt1
« Reply #17 on: January 17, 2022, 04:39:42 PM »
I don't think I'm up for that.
  • Old Goof
« Reply #18 on: January 17, 2022, 06:56:21 PM »
Take a solid punch and knock them out then you can adjust them correctly.
Don't do it on the truck. On the ground over a piece of wood.
Offline bigben5054
« Reply #19 on: January 18, 2022, 11:42:41 AM »
Wouldn't the rear drums be self-adjusting?  Loosen them all the way, install the drums/tires/wheels, then back up a little, hit brakes (repeat a few times).
Online Shifty
  • I bleed Bowtie red...
« Reply #20 on: January 18, 2022, 11:51:42 AM »
It has to be fairly close....I've adjusted shoes out so far that it took an act of congress to get the drum back on (un-punched drums), and that's pretty much the best you can do.  Next time I run into that, I'm drilling and dremelling an adjusting hole.
98 C2500 ext cab longbed
« Reply #21 on: January 18, 2022, 03:55:22 PM »
You can just drill a hole and pop a grommet in the hole. It doesn't have to be elongated.
