73-87 Chevy _ GMC Trucks => Interior & Equipment => Topic started by: hotrod24 on April 21, 2008, 01:29:24 PM
how do you get the head light switch out of the dash is there a clip or something
On the side of the switch there should be a pin you need to press in and pull the knob out at the same time .
thanks
pat
p.s. make sure the knob is in the off position meaning all the way in
C, K, R & V MODELS
Disconnect battery ground cable.
Reaching behind instrument cluster, depress shaft retaining button and remove switch knob and rod.
Remove left side instrument cluster bezel screws, then pull outward on bezel and hold switch retaining nut with wrench,
Disconnect wiring connector, then rotate switch counterclockwise and remove from vehicle.
Reverse procedure to install.
thanks
as you can see i got the head light switch out and every thing out of the dash
(http://i222.photobucket.com/albums/dd224/74chevy/103_0819.jpg)
(http://i222.photobucket.com/albums/dd224/74chevy/103_0820.jpg)
Hotrod, I'm confused!! You gotta column change and floor change? Whats going on!!
know man it is a auto and 4wd
:-[ lol feel a bit silly for asking that - not seen a 4x4 b4!
that is ok man
