Been a while since I posted anything on my truck but like many of you between the family, job and truck I am swamped. I appreciate all of the nice threads you guys post and use them constantly! Thank you!
Anyways I have completed the sound system in my '77 Stepside. I went with a Custom AutoSounds 300 watt chrome dual tuner knob head unit. Very nice product, simple to use and the 75Watts per channel is very handy.
I also have installed Custom Auto Sounds 6.5" kick panel speakers. They look very nice but 6.5's are just too tinny for my taste. Good for listening to talk radio but in a loud truck with a V-8 and headers you will need to step it up a notch.
I'm a bit of a car audio audiophile. On a budget. If you are like me and don't have tons of cash for the very high end stuff my first choice is always Rockford Fosgate. My jeep daily driver has a full RF system including 1200 watt amp, dual P3 10" subs, all component speakers are RF Punch line and wiring and battery terminals are all fosgate too. I dig the quality of the gear, its durable and they sound great.
That said this threads about speaker brackets...
The brackets 73-87 sells are of excellent quality. They include color directions and stainless mounting screws. I was shocked at how nice they are. They will require some prep work on your part and here is what I did...
Because I chose RF Punch 4 way 6x9's, following 73-87's advice I had to use spacers on top of the brackets due to the large magnet size of the Fosgate Punch's. There were two available on Amazon and I chose the more expensive option which were by "Metra". They were inch and a half thick and flat in shape. The Scosche models are angled and that had me thinking I may not want the speakers any more angled than they already would be.
TO help with sound quality I painted the inside and outside of the spacers with an awesome product from Duplicolor called UnderCoat Sound Eliminator
I used an entire can on the spacers and also on the inside of the cab corners. You want to optimize the "enclosure" as best you can. Why do a crappy job? I just can't.
Many coats until it was good and thick. Has a cool texture and rubberized feel. The can cost me 5 bucks at Advance. I'd use it again for sure but be warned it takes more than a few minutes to dry.
Here is what the 6x9's look mounted to the spacers after the rubber paint:
Waited a couple days for the brackets to get here. Total time from order to delivery was 5 days. He shipped them on wednesday and I had em on saturday. Good stuff for a small retailer. These babies are Made in the USA!! My man!
For prep I used Motzenbockers which is available at Home Depot. The brackets come with a light coat of some oily preservative (not cosmoline but similar). The stuff comes off easy with the motzenbockers and I didn't have a single fish eye in the paint. Here they are with their first coat of sound deadener applied to the inside of the brackets:
With that done it's time to prep and spray the exterior of the brackets. I used Rustoleum white metal primer followed by gloss red enamel followed up by Rustoleum gloss clear coat. Many coats plus the heat gun (lightly)!
I let em hang dry for about 15 hours before mounting...
Next up was carefully mounting the 6x9's with the brackets and spacers. I chose to solder the wires to the speaker terminals. Speaker wire I used was JL Audio 14 gauge. I always use flux when soldering and heat shrink whenever possible.
The holes on the brackets had to be widened out a bit to accept the included button head stainless steel screws. After that I drilled the holes on the cab corners and mounted them.
Here you see the full system including 500watt Kicker amp (I had one brand new sitting around so in it went, very nice amp by the way), Rockford's 12" Prime R2 Shallow mount subwoofer and the brackets with 6x9's. The amp is held down with an old ruck sack strap I had. Wiring for the amp is 4 gauge JL audio with the ground wire ran through the floor to the chassis. Hole in chassis is lined with a rubber grommet from Lowes. Do the job right!
The verdict:
Yes it's a lot of work. Several times I had to walk away. But in the end to me it is worth it. The sound quality (even without the sub) is not even in the same league as the 6.5"s. Not even close. The 4 way RF 6x9's get plenty of power to do their job with the Custom Auto Sounds head unit. Bass is decent and mids and highs are excellent. Combine the 6x9's with the entry level RF Prime subwoofer and the sound quality is outstanding. The 6x9's add a tremendous amount of depth to the music. I have a feeling the Duplicolor rubberized coating helps a lot. I will get some more pics if you need em.
