Author Topic: Windshield wiper hose  (Read 817 times)
Offline recoil
« on: April 26, 2024, 10:03:41 AM »
Are there "clips" of some sort the hoses attach to on the wiper blade assembly?  I don't see anything to plug the hoses into.  They are just dangling and flop around.
Thank you!
Steve
Hampton, VA
1985 C10; LS swapped.  It belonged to my Uncle Freddie who passed away in 2022.
Offline Mike81K10
Re: Windshield wiper hose
« Reply #1 on: April 26, 2024, 08:28:16 PM »
The hose terminates at two spray nozzles that is attached to the cowl cover with a screw. It sprays on the windshield from the nozzle and does not connect to the wiper.
I lived in Hampton, VA when I was stationed there for the Air Force.
« Last Edit: April 26, 2024, 11:27:54 PM by Mike81K10 »
« Reply #2 on: April 29, 2024, 10:32:31 AM »
Yes there are plastic clips used on the later versions.  They are thin and typically dry rotted.   I don't know of a source for them.
Offline recoil
« Reply #3 on: April 30, 2024, 02:16:36 PM »
Hey Mike!
Nice.  I'm down in the Fox Hill area.
Mine have hoses that route to each wiper blade but are dangling, like they used to plug into something (guessing a nozzle).
It's an 85 so maybe a later model that the cowl one?
Steve
Offline recoil
« Reply #4 on: April 30, 2024, 02:17:02 PM »
Thanks.  I'll continue to look.
Steve
Online bd
« Reply #5 on: April 30, 2024, 02:35:12 PM »
The later design windshield washer plumbing has a hose nipple immediately adjacent to each wiper arm axle that protrudes ~1" from the cowl.  The nozzles are built into the business end of the wiper arms near the wiper blade attachment pins.  The hose "clip" was more like a 4" long conduit that snapped onto the arm from below.  You may be able to fabricate a makeshift replacement from some UV stabilized black plastic tubing.
Offline Mike81K10
« Reply #6 on: April 30, 2024, 02:49:23 PM »
I just check online at the local parts store. They sell the wiper arm with all intact (wiper arm, nozzle, hose, and spray tip) for less than $30.
If the local parts stores have it, perhaps the forum's store will also have it.
Online ehjorten
« Reply #7 on: May 01, 2024, 08:44:50 AM »
Not only that, but the cowl panel had larger openings around the wiper posts to accommodate the washer hose routing.
-Erik-
« Reply #8 on: May 02, 2024, 04:45:13 PM »
Google this part # 15581004
« Reply #9 on: May 03, 2024, 02:13:01 PM »
No current vendor for that...
