Author Topic: Something is scrapping the driveshaft!  (Read 237 times)
Offline philo_beddoe
  • 77 C-10
« on: April 18, 2024, 04:08:42 PM »
Well, I know what is hitting it, had lots of bags of soil, mulch, that sort of thing in the bed, on way home from wmart, when hitting a drop in the road, or bump, I could hear the scrape. Why is this hitting, can I cut a space in this stupid rivited on box? And why is it rivited, and not simple bolts?
Offline Swampyankee74
  • Keep em alive
Re: Something is scrapping the driveshaft!
« Reply #1 on: April 18, 2024, 06:36:27 PM »
Looks like a bracket for a bearing on a two piece driveshaft.  If so grind the rivets off and pull the bracket
Offline Scott91370
« Reply #2 on: April 19, 2024, 11:05:20 AM »
I agree, it does look like it would be a carrier bearing mount.  If you're never going back to a 2 piece drive shaft, just cut the entire mount out.
  • 77 C-10
« Reply #3 on: April 23, 2024, 08:44:48 PM »
Yup, so far that’s the plan. Thanks
  • 77 C-10
« Reply #4 on: April 28, 2024, 10:24:08 PM »
Well I unriveted that useless box, gone! Cleaned the area and painted. Looks like it was never there. Will add pic when I get a chance.
Offline Shifty
  • I bleed Bowtie red...
« Reply #5 on: April 29, 2024, 09:29:54 AM »
Aww man!  Why did you remove your roadkill-scraper-mount?  ;D
98 C2500 ext cab longbed
