73-87 Chevy _ GMC Trucks => Body, Glass & Paint => Topic started by: hotrod24 on March 10, 2009, 07:56:31 PM
ok templates i think its called it looks like this where can i get them you can just roll them out and then paint over them and then pull them off and it makes stripes
http://s228.photobucket.com/albums/ee287/dhouston_album/?action=view¤t=DSC00459.jpg
well i looked around and found that you take masking tape and cut it but i thought you could buy it cut already
hope this helps.
http://www.phoenixgraphix.com/
http://www.stencilsandstripes.com/index.asp
yea just what i was looking for thanks
78BB, Cool... I order alot from pheonix aswell...
hotrod.... you'll like that site
Hotrod, What is it that you are trying to paint & on what vehicle?
I think personally it be better to just use fine line tape and paper and lay down the color of the stripes you want and use that color 1st as your basecoat, then mask off the stripes. Reapply the color of the truck you want.Pull the tape and paper off and tack it off and clear over it.But thats just me ::)
thanks
pat
well i like the color on the boss in the first post it is a cool gray metallic with hotrod black and i would like to buy a cowl hood from chris and do something like that or paint the cowl black on the hood and just leave the rest gray my truck is a 4x4 and it will have 33s and a lift i think it would look bad
You dont plan on doing the stripes down the sides do you? Did you know from the factory the blacked out on the 69 boss 302 was done originally with vinyl dye ? You couldnt wax it just wash it if you got wax on it it was pretty much done for.
thanks
pat
no i think just on the hood and the chorme will take over to dye that would not be good
