73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: hotrod24 on December 17, 2008, 06:21:27 pm
Title: rear end
Post by: hotrod24 on December 17, 2008, 06:21:27 pm
how would i do a normal rebiuld for a 78 chevy
Title: Re: rear end
Post by: Captkaos on December 17, 2008, 06:35:02 pm
As in replace all the internals?  You would need some dial indicators to set it up in the end for the gears.
Title: Re: rear end
Post by: hotrod24 on December 17, 2008, 06:41:45 pm
i mean to just freshing things up how would i go about that?
Title: Re: rear end
Post by: hotrod24 on December 17, 2008, 11:04:50 pm
how can i find out what gears i have it is a 14 bolt
Title: Re: rear end
Post by: joesgarage71 on December 18, 2008, 08:47:44 am
 Should have a sticker in the glove box with options on it. If not you can count the teeth on the gears/there should be a stamp on the outter edge of the ring gear with the number of teeth divide them and you'll have the ratio.
 If there nothing wrong with the rear end  just replace the bearings and seals/gaskets.
 "If it ain't broke don't fix it"
Title: Re: rear end
Post by: hotrod24 on December 18, 2008, 10:57:29 am
ok thanks
