73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: lincoln welder on January 20, 2009, 03:50:44 pm
In the final stages of my build. 83' stepside 2wd, 500 HP 489 BB :o, 350 trans, 9" rear w 4.11 gears,31"x16.5" tires. Im running the stock leaf spring configuration and planing on fabricating traction bars. anyone had experience drag-in a heavy chevy?
Cal-tracs hands down if you want bolt on traction.
thats the going reply. some one said adjustable bars from under the rear to the bottom of the frame below the back of the cab was extremely effective.
HaulinIt has a "duped" version of Caltracs on his drag truck.
If you "link" a leaf setup, you have to have housing floaters on the connection to allow the links to travel without binding.
http://www.competitionengineering.com/articles/chassis2.asp
Cal-tracs.
thanks guys, shootin for mid 11's.
Thats right Truck arms done right is hard to beat.
CLICK Here (http://www.hotrodstohell.net/) for a company that specializes in truck-arm suspension, if you are interested.
event. I bolded and changed that since I couldn't tell you linked it.
