73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: nikesb1111 on January 26, 2009, 01:24:20 pm
Title: oil leak
Post by: nikesb1111 on January 26, 2009, 01:24:20 pm
so i have an oil leak in my 86 k10 coming from around the inspection plate, its a 350 with a 700r4. Its leaking motor oil but i cant really tell exactly where its coming from but its all over that area. I was thinking maybe the rear main seal. Any ideas? also i have holley 600 four barrel and whenever i take the truck out of gear the fast idle kicks on, any ideas?
Title: Re: oil leak
Post by: Captkaos on January 26, 2009, 01:29:24 pm
pull the cover and spray it off to find the leak.
Title: Re: oil leak
Post by: nikesb1111 on January 26, 2009, 01:56:53 pm
i pulled the cover and everythings dry. Heres a couple pics i snapped.
(http://i308.photobucket.com/albums/kk346/nikesb1111/IMG_6705.jpg)
(http://i308.photobucket.com/albums/kk346/nikesb1111/IMG_6706.jpg)
(http://i308.photobucket.com/albums/kk346/nikesb1111/IMG_6704.jpg)
(http://i308.photobucket.com/albums/kk346/nikesb1111/IMG_6703.jpg)
Title: Re: oil leak
Post by: eventhorizon66 on January 26, 2009, 02:03:18 pm
It could also be a leak at the rear of the intake manifold, where it meets the block.
Title: Re: oil leak
Post by: dumbucket1 on January 26, 2009, 02:16:22 pm
or out of the oil pressure sending unit hole, or out of the distributor hole
Title: Re: oil leak
Post by: 84chevysilverado on January 26, 2009, 03:09:06 pm
we had the same problem at my work with one of the work trucks. what we did is GM sells some kinda seal renewer that you put into your motor oil  wich swells up the seals and makes them not leak anymore. worked really well still hasnt leaked. but this is also just a quick fix and only works if its leaking around the seals.hope that helps
Title: Re: oil leak
Post by: VileZambonie on January 26, 2009, 08:27:10 pm
your oil pan looks rotted amongst the other leaks.
