73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: p7387 on February 07, 2009, 12:54:07 pm
Title: Break Lines - am i in the right section?
Post by: p7387 on February 07, 2009, 12:54:07 pm
i have been told that i should carefully inspect the break lines as these are prone to horrible rust issues. is there anything important i need to be aware of?
if the lines do infact need to be replaced is this worth getting mail order or should any good parts store have them.
thanks
Title: Re: Break Lines - am i in the right section?
Post by: frogman68 on February 07, 2009, 04:53:57 pm
if you are rebuilding the truck I would replace em since everything is apart if you are just going over it for safety anything more than surface rust I would replace. Remember that brake lines are double flared and compression fittings are a no no .
You can order than pre bent or you can go to any auto store and get straight line and bend it to what you need.
Post by: dumbucket1 on February 07, 2009, 07:44:16 pm
they are probably fine but if you do get new ones I have bought from both www.inlinetube.com and www.classictube.com and their products were excellent and a very fast turnaround.
