73-87 Chevy _ GMC Trucks => Performance => Topic started by: 85ChevyJRF on February 10, 2009, 11:20:00 pm
Title: Cam specs on a stock 305
Post by: 85ChevyJRF on February 10, 2009, 11:20:00 pm
Does anyone know the stock cam specs on a stock 305? And what size cam to go with on a stock motor just to get a thump?
Title: Re: Cam specs on a stock 305
Post by: Captkaos on February 11, 2009, 11:11:55 am
SMALL like less than .400" lift..  I don't remember the exacts though.
You would have to get a cam, lifter and spring set (in my opinion) to go to something with some "thump".
I hear the Thumpr Cams will give the sound though.
Post by: 78 Chevyrado on February 11, 2009, 11:23:54 am
I've been looking at some cams that thump too.  I'm trying to get the smallest cam I can that you can still hear it.  I have a 350, but the 305 won't be too far off.
For my truck with a 350 I've about got it narrowed down to a comp cams xe262 or xe268.  Here's the specs from Comp:
XE262:
http://www.compcams.com/Cam_Specs/CamDetails.aspx?csid=85&sb=2 (http://www.compcams.com/Cam_Specs/CamDetails.aspx?csid=85&sb=2)
XE268:
http://www.compcams.com/Cam_Specs/CamDetails.aspx?csid=86&sb=2 (http://www.compcams.com/Cam_Specs/CamDetails.aspx?csid=86&sb=2)
Here's a video of the xe262 in a 350.   being in a 350 means it would be a bit lumpier in your 305.  I'm pretty sure in a 305 I'd get the xe262.
http://www.streetfire.net/video/83-Z28-Cam-idle_99231.htm (http://www.streetfire.net/video/83-Z28-Cam-idle_99231.htm)
Here's a xe268 in a 350, again it would be a little bit rougher in yours.
http://www.youtube.com/watch?v=kukI2LnxrqY&feature=channel_page (http://www.youtube.com/watch?v=kukI2LnxrqY&feature=channel_page)
I've been looking at the thumpr, and I'm just not sure enough how it would be in a big truck.  it makes good power but it makes it way on up the rpm range.
Here's a thumpr vid for fun  it's in a 350.
http://www.youtube.com/watch?v=j97kabzMOYA&feature=related (http://www.youtube.com/watch?v=j97kabzMOYA&feature=related)
All the cars in the videos are idling in park or neutral.  if you have an automatic, when you put it in gear, it will lope even more.
Like capt said, all of these cams require new springs because of the higher lift.  along with the lifters, etc...
Post by: 82Shortbed on February 12, 2009, 11:37:06 pm
I sold a guy at work this cam....
Crane 100172
http://www.youtube.com/watch?v=sYMVg2P2LGY
He put it in a 90 Chevy Silverado, swapped it to carb, stock 193 heads.  he said he swapped a set of Z28 springs onto the heads, and is using a performer intake, headers, and a 600 Holley.  wish I had a video of it.  sounds decent.  not too loud though because of the crappy compression.
Post by: 85ChevyJRF on February 13, 2009, 02:58:16 pm
The thumpr in that bel air is what my truck would prob sound like cause i have the same mufflers
Post by: VileZambonie on February 13, 2009, 03:16:46 pm
The stock 305 lobe lift was .2484 intake and .2667 exhaust.
Valve lift .373  in .400 ex
Post by: 85ChevyJRF on February 17, 2009, 09:51:18 pm
Thanks Vile
