73-87 Chevy _ GMC Trucks => Projects Posts (NOT VEHICLES) => Topic started by: crazedhick3 on February 25, 2009, 08:00:37 pm
Title: Starting paint booth
Post by: crazedhick3 on February 25, 2009, 08:00:37 pm
Here are a few pics of the Temporary booth I am attempting to build so I can get my frame painted.  I hung 1 1/4" pvc from the trusses in the garage.  I am able to utilize the Air handler from my heat pump to pressurize the booth.  I plan to hang plastic from the pvc down to the floor and seal it up with mastic tape.  At the other end i plan on exhausting the air through a 14' flex duct out the garage door.  I will post better and more complete pics when i am done.  I just wanted to get some thoughts.  Thanks.
Title: Re: Starting paint booth
Post by: VileZambonie on February 25, 2009, 08:09:43 pm
Sounds doable. Are you planning on running the heat or just the blower motor?
Post by: zieg85 on February 25, 2009, 08:25:11 pm
Keep in mind rolled plastic, at least most of them, builds up static charge fairly easily and 1 spark is all it takes to.... well, just be carefull.
Post by: Blazin on February 25, 2009, 10:36:30 pm
Allot of work for a frame. If worried about over spray I would just hang up some traps to keep it in one area.
Post by: crazedhick3 on February 27, 2009, 09:18:11 pm
It is a whole lot of work, but if you happen to keep up with my project, you will notice I aint in a real hurry. :)  But here are a few more pics.  Hopefully I will get her coated by Sunday or Monday.
Post by: 80stepsideguy on February 27, 2009, 10:52:36 pm
Looks good man  what brand of paint are you using on the frame?
thanks
pat
Post by: 78 Chevyrado on February 28, 2009, 02:38:20 am
Good job!
Post by: oldwhity on February 28, 2009, 07:49:07 am
That's a pretty slick idea. I take it no sparks ;)
Post by: crazedhick3 on February 28, 2009, 09:36:32 am
No, no sparks, I hope.  With all the rain this weekend, if i'm able to get spraying tomorrow, I hope to bring up humidity a little by opening the garage windows.  The air handler motor will be isolated from the fumes being that only the supply side is hooked up.
80stepside, I decided to give Eastwoods 2K ceramic a try.  Ill keep you posted on how it turns out.
Post by: crazedhick3 on March 04, 2009, 06:05:56 pm
Alright, its all done and came out great.  The Eastwood 2K ceramic sprayed real nice.  Booth performed good and just as I had planned.  The heat from the heat pump performed better than expected.  I was able to heat the booth to 80 degrees on a 30 degree day.
Post by: Captkaos on March 04, 2009, 06:12:06 pm
That turned out good.
Post by: 69byrd on March 04, 2009, 09:29:50 pm
That frame looks great! Good job man.
Post by: CruzinHigh on March 21, 2009, 09:34:24 am
Cool!  Love the do it yourself job that comes out looking professional with a little (or a lot) of ingenuity like you've demonstrated!
Keep us posted!
Post by: hotrodpc on April 04, 2009, 11:44:22 pm
Awesome !!! I want my frame to look good and clean, but I was not expecting or thinking of having it look that good. I think you may have just gave me alot more work to do on my projects. Kinda raised my standards a bit. After all that, will you be driving this vehicle in the rain??? Looks to nice to mess up.
Post by: crazedhick3 on April 07, 2009, 04:18:55 pm
IF I ever get it back together, I dont think it will see alot of rain. :)  I actually have the frame hung up in the ceiling of the garage now so I can make room for some spring and summer projects I have.  I have a trailer I need to paint and its time to start fixing some of the rust on the 89 Suburban I have.  My plan is to have the rust in the tailgate and in the roof fixed and would like to shoot the it with a hot rod black and get a 4" lift by summer time.  As you can see, Im not in a hurry with the '77, but I plan on at least having the suspension and a rolling chassis by the end of the year.
Post by: metalhead on April 13, 2009, 07:05:42 pm
Looks great!
Post by: CruzByU on April 22, 2009, 10:22:40 am
Very nice job, how did you prep the frame? Sand/media blast, or by hand with wire wheel, sanding disk.....etc.
Post by: crazedhick3 on April 23, 2009, 05:42:37 pm
All of the above!!  Mostly sand blasted.
Post by: Engineer on July 26, 2009, 09:26:35 pm
Outstanding. Looks good.
I plan on doing the same to my truck. Right now I am in the tear down stage, so sand blasting, and painting are still down the road a little way yet.
Post by: comp on July 27, 2009, 12:30:10 am
  Nice work
