73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => The Lows (Lowering/Drops) => Topic started by: HeAvYChEvY! on February 27, 2009, 06:44:48 pm
Title: airbag ? 78 shortbed
Post by: HeAvYChEvY! on February 27, 2009, 06:44:48 pm
im planning on buying 22x 9's w/ 265 x40 or 35 tires. What are my options on lowering truck with air and w/o airbags. any kits available?
Title: Re: airbag ? 78 shortbed
Post by: Captkaos on March 01, 2009, 07:00:01 pm
AirRide has a kit for Air
Almost anyone can get a static kit including me.  Just need to know how low you want to be.
Post by: Captkaos on March 01, 2009, 10:36:49 pm
On Air vs Static,
Airbags only replace the springs in the truck, so whatever you go with now will be the same minus the springs (in the front) you still need spindles to get a low ride height and just change the install height of the bags to match later on.
What are you plans on the rear?  Are you going to do air over leaf or a 4link or what?  If you go 4link in the rear with coil-overs when you bag it, you just basically replace those.  If you go air over leaf, you just remove more leafs (down to 2) and put a bag on top.
I would weigh the cost of both before you decide as you are still going to have to lower the truck when you bag it.  Airbags just add adjustability and the ability to let all the air out when parked.
Post by: HeAvYChEvY! on March 04, 2009, 05:00:36 pm
thanks Capt
