73-87 Chevy _ GMC Trucks => 4 Wheel Drives => Topic started by: 355shortbed on March 13, 2009, 08:13:20 pm
i have a gear driven transfer case in a 77 chevy swb, not sure wat the number is, has anyone changed the seal in the front outputshaft that goes to front axle, ? how hard?
easy. Remove the driveshaft. Mark the nut on the companion flange to the shaft and the nut. Thats 3 witness marks. Just use a center punch. Take off the nut, flange and seal. You will need to ID the transfercase to get the right seal and fluid.
cool thanx man, its bad , goes through like almost a quart a week
Depending on the transfer case there may be in inner seal also. It looks like a starburst
(http://www.aaronovadia.com/clients/photoshopit/display/starbursttut.jpg)
any one know wat to torque the front output shaft nut to on the transfer case, its a np205
