73-87 Chevy _ GMC Trucks => Suburbans => Topic started by: Stowburb on March 27, 2009, 03:56:59 pm
Title: Water leak
Post by: Stowburb on March 27, 2009, 03:56:59 pm
Hey Guys,
 I am installing OEM carpet in my '91 burb, it had a rubber floor in it and when i removed it i found the floor to be soaked! Best i can tell it is coming from somewhere near where the door hinges bolt to the body.
 Has anyone ran into this? is there a common problem with these trucks? and what can i do to correct it?
Thanks for any help, just dont want my " rustless" truck to rust!
 Chris
Title: Re: Water leak
Post by: oldwhity on March 27, 2009, 09:33:34 pm
Dry everything up and set a sprinkler on the side that is leaking and wait. You should be able to see the water coming in and pinpoint the source of the leak. Good luck.
Post by: justpball on May 04, 2009, 12:03:26 pm
mine is doing the samething on my 2wd...I am going to be looking for mine and if I come up with anything I will post it here...
Post by: VileZambonie on May 04, 2009, 12:56:25 pm
Look around the windshield and kick panel area. The cowl can back up also.
Post by: Captkaos on May 04, 2009, 01:15:52 pm
You may also want to open up the cowl area and see if the seal is rusted.  I did my annual cowl cleanup about 3 weeks ago to get the junk out of there.
