73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: chevyboy1983 on March 29, 2009, 09:16:04 pm
Title: distibutor mark rubbed off
Post by: chevyboy1983 on March 29, 2009, 09:16:04 pm
I put a mark on the distributor when i took it out but it rubbed off. How do I know it is right before i put it back in?  I didn't turn over the engine since the dist. has been out but when i took it out i think it might have moved a tooth or two. Will it go in if the gears moved on the distributor?
Title: Re: distibutor mark rubbed off
Post by: Irish_Alley on March 29, 2009, 11:54:53 pm
the dis should only go in two ways from what i know. its eather going in the right way or 180 out since the oil pump has a blade type connection that connects the distributor as long as your close it should fall in place maybe you have to lift the dist out a bit turn it a little then reset it back in place but it should fall in sooner or later
Post by: Lt.Del on March 30, 2009, 09:02:00 am
What i usually do is remove the dist. cap prior to removing the distributor.  That way you know which way the rotor points.  If the engine doesn't turn at all when working on it, just place the distributor in w/ the rotor pointing the same direction.
What you can do is look at your timing marks on the blancer and the metal tab guage over the balancer.  Know the firing order....  1-8-4-3-6-5-7-2.  left side on engine (drivers side) from front of engine: 1-3-5-7 and right side: 2-4-6-8.
When the timing mark gets close to 0 or TDC, you know you are near the firing of #1 cylinder.  Simply point the rotor towards the #1 spark plug wire and the rest will follow suit.
The only problem with this method is as mentioned, it could be 180 degrees off, meaning, trying to fire on the exhaust stroke.  IN other words the balancer makes two revolutions for every one fire of each plug.
If it won't fire up right away, remove the distr. and turn engine one full revolution to get it on firing stroke, put distr. back in with rotor pointing same way.  Or, just remove distr and point the rotor 180 around, pointing at #6 plug. That should fire during #1 exhaust stroke.
Now, you know the distr turns the oil pump.  Sometimes it is a little tricky getting the distr. to fall completely down for the shaft to fit inside the oil pump, but it will eventually.  YOu may have to turn the distr left or right, then once it falls, turn the distr. back as if timing it  to the approximate locaton.
There are some who will tell you to remove the #1 plug and see if piston is on top, or put some tissue or something in the cylinder plug hole and when it pops out when turning the crank (5/8 bolt at crank) you are at #1 TDC top dead center.  Whatever floats your boat.
