73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: 75??? franken-trunk on March 30, 2009, 09:28:57 pm
whats the best way to get out the six leaf spring and shackle bolts for the rear suspension from start to finish please...
If its anything like my truck, the bolts are seized in the metal bushing. I used a torch to cut off the head of the bolt and the thread end of the bolt. I then took the torch and tried to shorten the bolt so it would be short enough to slide out of the hanger and/or shackle. I then used a crowbar and pryed down on the leaf spring to remove it. This will catch your bushings on fire so you'll need new ones. I have a hard time explaining things so this might be a little hard to understand. lol somebody else might have another way....thats my way. Andy
i got a pic of me doing it....hold on and ill get it up
(http://i193.photobucket.com/albums/z177/Bighemi353/0322091413.jpg)
here ya go....guess it wasn't exactly how i explained.... but i hope you get the picture... lol
i believe new rubber or poly bushing kits are around $50 or $60.... and i believe they come with the metal bushings as well.
Andy
If you have several blades, patience, and a sawsall you can cut the bolts inside the hangers.
Like Blazin said, A sawzall may be the way to go. I've done many springs that way. Just stock up on blades and have at it.
Energy Suspension makes a nice polyurethane bushings kit that includes both the spring and shackle bushings along with the steel sleeves. Just make sure to get the right kit for your truck, I believe they come in 2 sizes, 1.5" and 1.75". And don't forget some new grade 8 hardware.
i am replacing the bushing's on my 82, or i should say have been for 2 days. i ended up using a sawzall and cutting the bolts in the same place big hemi torched his. used 1 sawzall blade per cut. then to get the bushings out, i drilled out the rubber, then took the sawzall to the outer sleeve to cut it into 2 peices, then peeled it inwards to get it to come loose (rusted in real bad). i thought that i would have this done in a day, but maybe i just work slow... good luck!!
thats what i was thinking cuz the bushings are way good so i wanna keep them and im broke from the frame swap im doing... is there a way to get the remainging bolt out of the eyelet???
bullpin and a 3lb pursuader.
ccz, from my experience with my k-20 and s-10 have not had any luck with this route. just my $0.02. Andy
