73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: Mike Phillips on April 13, 2009, 07:47:49 am
Title: How to identify Long or Short water pump?
Post by: Mike Phillips on April 13, 2009, 07:47:49 am
Is there a way to identify or measure a water pump to tell if it's the long or short water pump?
There's a complete bracket set-up for a big block chevy on eBay that I want to bid on but it's for the long water pump option.  Motor is a stock 454 out of a 1986 2-wheel drive Suburban.
Title: Re: How to identify Long or Short water pump?
Post by: frogman68 on April 13, 2009, 07:49:48 am
If you can stick your hand between the pump and the timing chain cover its long if you cant its short.
Thats my method others might have another idea.
I think you can put the short or long on as long as you compensate at the fan.
Post by: Captkaos on April 13, 2009, 09:48:31 am
If it is from an 86 454, it is long a long pump.
Post by: Mike Phillips on April 13, 2009, 11:12:51 am
Here's what it looks like,
(http://www.showcargarage.com/gallery/files/1/waterpump.jpg)
The eBay auction is almost up, think I'm going to bid on these brackets.  Not sure if these are priced at fair market value though.  Any ideas?  I don't want to use the serpentine system no matter how great it might be, I want to keep my engine simple.
eBay auction
http://tinyurl.com/csanm6
Mike
Post by: Mike Phillips on April 13, 2009, 11:14:37 am
Just realized the auction says,
a 1971-79 Big Block Chevy Engine
I have a 1986 era Mark IV 454
Guest this means these brackets won't fit the block?
Post by: Mike Phillips on April 13, 2009, 11:32:48 am
My mechanic friend in Oregon says the brackets should all work fine on my block.  Said I'll have to get a different water pump because of the way the serpentine pump was designed to rotate.
Post by: Captkaos on April 13, 2009, 11:36:08 am
same BBC,  I read you other post, I would use the factory Serpentine setup....
Post by: Captkaos on April 13, 2009, 11:37:26 am
You would have to get a new pump if you are eliminating serpentine.  I would use serpenting over these.  I have V-belts on mine and would switch in a heartbeat.
Post by: Mike Phillips on April 13, 2009, 11:44:34 am
I appreciate your advice and respect it too, but I am really big into keeping my engine compartment Simple Simon and traditional v-belt system is a better option for my preferences.
