73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: murraygmc on April 13, 2009, 02:19:23 pm
hay guys i have a 76 305 and on the gass pump i dont have a return line so what do i do with the return line going back to the tank plug it ? and i have no charcole can any more and have lines that whent to what as well shuld i plug them to ?
Why don't you have a return line? The pump has an internal bleed but you should run a pressure regulator and a return if it's an aftermarket pump.
idk why the pump dont have a return line. what do i do about the hoses that went down to the chaircole can plug them or what thanks
i know on my 75 motor it didn't have a return line but my 86 does so when i swapped motors i also swapped pumps
