73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: chronos on April 17, 2009, 01:34:19 pm
Title: Short box 4x4 frame.....
Post by: chronos on April 17, 2009, 01:34:19 pm
Thinking of my project options.
I have a short box 4x4 frame, can I swap over everthing
from my 88 full size Jimmy onto this frame?
What is different between frames?
Thanks
Title: Re: Short box 4x4 frame.....
Post by: HAULIN IT on April 17, 2009, 02:15:32 pm
Chronos, The Blazer frame is 6"-8" shorter than the short bed truck frame in the middle, making the wheelbase different, so it's a no-go. Lorne
Post by: choptop on April 17, 2009, 09:02:32 pm
Lorne is right. You would have to shorten the frame and relocated the body mounts and even then, I dont think it would work right.
Post by: Blazin on April 18, 2009, 07:23:55 am
Running gear except the rear drive shaft will all bolt in pretty simple. Body will not fit even with the cab mount brackets. Frame is completely different.
Post by: Captkaos on April 20, 2009, 03:58:21 pm
As Blazin stated, the body will not fit, there is nothing simular on the frame except for the portion under your feet forward.
