		73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: Fast_suv on April 19, 2009, 08:05:04 pm
				New guy with a New truck and old Q probably--
Hey all,
First off, GREAT site.
I Picked up a 1976 chevy K10 PU two weekends ago with a fresh 350 with a extremely mild comp cam in it and the runs well. it has the 6" Tuff Country lift on it with the steering kit as well. Its sitting on a set of 16/35/15lt Swamper Boggers and nice set of polished deep wheels.
Now other than that I am learning as much as fast as i can and this site has been great so far. I have rewired all the gauges (that you to this site) and got allot of other information.
So like I said this is my first lifted vehicle; my first carb'ed vehicle; and first 73-87 PU.
so lets start...
1) I have identified my transfer case as the N02 but my not sure what position is what on the shifter in the cab. (3 spd manual tranny)
2) I have a 44 front axle, the tube coming off the top if just hanging , should it be attached to anything?
3) I keep reading about Suspension Blocks, what are they and how do i know if that's what i have?
4) It has a 1406 edelbrock carburetor, on the left side is a little black zip tie near what i think is the choke and no wires running to it. Is that right?
5) Anything i should check before driving the truck allot? safety or reliability concerns??
Thanks guys
Jeff
				on the carb, the big black thing is the electric choke.   the zip tie, i'm not sure.  probably to hold the choke in a certain position?? not sure if that is right or not......
the hose under the truck seems to be the vent hose for the axle.   the top of that hose should be attached to the crossmember right above or on the frame somewhere.
on the transfer case, you're shifter looks like mine, but i have a np205, mine goes (i think) from top to bottom:
4L
N
2H
4H
not sure what the n02 is...
suspension blocks are a method for lifting the rear of the truck.  they are put in between the axle perches and the leaf springs.
check all the brakes, make sure you can stop.   all steering parts  are tight,  and drive away.   that's a nice truck you got there,  welcome to the site, enjoy the wealth of info!!!
				That is a cool looking truck. Welcome from West Texas. The tube off of the axle is the vent It needs to be lengthened and tied up to the frame
				I love the title of the thread, 'new truck, old carb'.  So you think the carb is old and truck is not? Or, if the truck is new to you, isn't the carb as well?
I know, I'm being picky.   Nice truck by the way.
				To get your choke operating, all you need to do is supply a 12v Ignition hot wire to one spade, and a ground wire to the other spade. For the ground, I just use a short piece of wire grounded to one of the 3 choke body screws. Your T Case shoud be a NP205.
				yeah, i meant np205...
When ever I'm not in 4wd and i try to put it in the position 2H where you guys are saying the truck doesnt go anywhere.
The dude i got it from said to leave it all the way up (looking like 4L) and if i do truck seems to drive ok... kinda weird.
Ill try agin tonight to see if i am just missing 2H and hitting N or something....
But WOW thanks so far you guys rock...
On additional Q.
my Pass side front wheel is missing 3 of 6 lugs and when trying to remove the hud to replace the 3 i just couldnt break it free... any tricks?
get a pipe, about 3 to 4 feet long and stick at least a 1/2' drive ratchet in it with the correct socket size (13/16"?).  That should give you the leverage you need.  I use a 3/4" drive myself for stubborn bolts/nuts, but not everyone has a set of those.
Wouldn't hurt to shoot it up with some penetrating oil before hand too.
				Hey Fast   Welcome.
They guys answered your questions and you should be good to go.  My brother has that same truck primer Gray just like yours. Nice truck.
Listen the choke on that carb. The tie strap is being used to to keep the choke arm from moving. The guy you bought it from was not using the choke and hated that the choke would close part way after full throttle running. He put that there so he would not have to worry about it.  Do you need a choke?   Does the truck start right up and keep running?  If not you will want to hook the choke back up. Like the guys said just supply the 12v. left side is NEG right is 12v. YOu want the 12v to be keyed.  Need help figuring how to adjst it let us know.
The vent tube you got covered.
The shifter.  Keep in mind the transfer case shifter does not just go up and down. There is a slight side movement.  All the way up to the front of the truck is for 2H.  All the way down is 4L  nothing else needed......lol      Also your transfer case could be a pain like mine. Mine wont shift until from low to high until the driveshaft stops.    Enjoy your truck.
On additional Q.
  Fast,  YOu mean trying to remove the inners of the HUB?  how much did you get out?    Careful there is a washer in there that can make you think that it is a nut and it is not. It is kinda thick.  There are only two nuts.  One washer is thick and all you have to do is pull it out.
				I'll try again when it stops raining and take some pics.
That is just what mine does... Good to know...
Thanks a Ton guys..
Last Question i think....
Is there any Ladder bars/traction bars that will work with the 1/2 ton rear? i see Tuff sells them for the 3/4 ton....
				What on earth would you want ladder bars for?   4x4 dont need ladder bars.
You getting wheel hop?    Lets look at something else as the problem.
				if i dont start out of first really slowly the back end bounces like crazy..
My buddies 2003 F250 with about an 6" lift and 37" tires was doing that too so he had to add them... if you have any other suggestions of what to look into that would be awesome... Like i said my first lifted truck...
				Well bro you should look at a few things.   Are the Tires Bald? Is there anything in the bed.  Does it have air shocks?  There has to be a good reason for the wheel hop.  Its not a light truck.
				Welcome from Maryland! My 81 gets a little wheel hop but only in reverse. I don't use reverse a whole lot so it doesn't annoy me enough to figure out why.
				I would check the torque on your springs and u-bolts and check the shocks. If they check out ok check your trans mount and driveline angles.
Yeah, I was suprised when id hopped them the first time too..
When you say check the torque on the springs you mean to make sure all is tight and to torque spec?
Tran mount look fairly new..
How dow i check my driveline angles?
				Wheel hop gets to be common on trucks that are lifted. When you lift a truck, the angle of the driveshaft is changed. So when power is applied to the driveshaft, it affects the arch on the rear springs. The springs tend to flatten out, and that energy causes the driveshaft to kick back around and the tires lose traction as the rear of the truck hops. So you can see why the driveline angle gets to be important- when the distance between the center of the driveshaft (also called propshaft) and the spring pack changes, something is gonna  happen to counteract that change. Higher lifts mean it takes less force,or torque,to make the truck hop.
Sometimes a helper spring can be added, or traction bars. A Bent wheel and the other things that the guys mentioned can cause the hop. But remember, when the engineering of the truck is altered there will be other changes to deal with..
Good to know.
I found a Site that sells set of Tuff Country Ladder Bars (359.00) and Super-Trac Traction Bar Kit (299.00) for the 1976 1/2 Ton K10.
I may order those but first i wnat to tune my Carb... Running insainly rich.i used 1/4 tank to go 5 miles.
Working on that and the Hub removal and lug replacement today.
				Need help reach out.  Email me at just-speed@earthlink.net for instant help.  Email comes to my phone aswell.
Thanks man
I got my speedometer working last night and then received my autometer speedometer in the mail like 10 min later.. Figures.....
Pics coming son....
Tons of parts to unload too
When i go to replace my lugs should the whole rotor com off or is it two separate pieces?
Thanks guys.....
				its two pieces but you can leave as one.    The Rotor is behind the hub. But they both must come off. They will come off as one kinda stuck together.
Summit just dropped off new lugs and nuts for me last night. Aswell as new Lockers. Gonna try some Mile Markers.
I tried and trid the other day and couldnt get them apart.. im trying again today i think... weather permitting
				Bro.........take them both off as one.......   You can leave them as one.
Sweet, thanks... I worked on cutting up the gage cluster for the autometer speedo yestorday between cutting the grass and picking up a sheet of MDF for speakers.... today hopefully is Stud replacement day. .. Saw you Post on wheel studs so ill try the torque wrench, washer, and blot way see if it works...
Pics tonight of the Before and after of everything so far...
Thanks for everyone's help so far!!!
				WOOOOHOOOOO got the lugs replaces and the carb adjusted some what..... BUT
I realized that the lift i hav eit a rough country 6" lift... witch uses these HUGE blocks in the back... from what i understand .. thats not what i want to use at all...
What can i do to fix that... ???
				remove the blocks and replace them with 6" lift springs.   i don't think they are that expensive, check on rough country's web site.   the blocls could be part of the problem with you're wheelhop...
Thats what my cousin said too....
another project   wooooooohooo
				SOOO i have a question ...again...
Im in the middle of my cab swap and im putting things baack togeather and noticed that my 4wd shifter only moves stright foward and backward due to the shifter having a metal guide preventing it from moving left to right. after pulling parts from about 5 different trucks in the pick and pull yard every 4wd they had had a slight left to right movement as you shifted foward..... like
------4hi-------
------ N -------
--------2hi-----
--------4lo-----
somthing like that (gear lables may be wrong)
What i want to know is, is my shifter right? there was a few thing on the truck when i got it that seemed "rigged" to work so i was curious if this could be one of them? if so i would like to have the correct selector. (when i go into the what i have labled as 4hi, N, or 2hi position it almost seems like it slips out to N very easy)
HELP lol
thanks guys
				best pic i have at work
Hey Fast   Welcome.
I hooked up the Choke yesterday and nothing happened. it doesnt seem to mave anything move or anything. Is there some sort of adjustment i need?
also i only have a supply line running from the fuel tank. Do i need the other two?
Runs really rich and takes a little to get her started... (still working on the fuel gauge too.. got it re wired but still reading weird on my multimeter)
				I dont know if this helps or not, but here is what my shifter looks like on my 91 sub....it does go down, then to the right
(http://www.delbridge.net/91u.jpg)
				CHOKE QUESTION
