73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: roadrage41 on April 22, 2009, 08:07:31 pm
Title: grounded out alternator - wont start
Post by: roadrage41 on April 22, 2009, 08:07:31 pm
long story short one of the spaghetti mess of wires under my hood, specifically the one that bolts to the back of the alternator grounded out. ignition does nothing now, where should i start to remedy the situation?
i went to turn it over, it made maybe half a crank, stopped and a puff of smoke came out from under the hood through the windshield vents.
the ignition when turned over doesnt even make the buzzer sound. my head and taillights still work, turn signals dont, tells me something in the ignition is borked.
help!?!?!?!?! lol
russ
Title: Re: grounded out alternator - wont start
Post by: VileZambonie on April 22, 2009, 08:12:23 pm
You burned your fusible link. Check off of the junction block on the firewall and down at the starter solenoid.
Post by: roadrage41 on April 22, 2009, 08:13:50 pm
vile we talking just needs new wires or needs new fuse panel et al. the dang things sitting in a grocery store parking lot til friday... grr.
Post by: VileZambonie on April 22, 2009, 08:16:57 pm
fix the grounded wire. Jumper the faulty fuse link to get it home. Then replace the fusible links.
Post by: VileZambonie on April 22, 2009, 08:19:24 pm
Here's a quick how to replace a fusible link.
*Chris maybe you can cut that and make it a how to post.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=7402.60
Post by: roadrage41 on April 23, 2009, 05:47:53 am
k i got it all figured out in theory, but the two wires on the b terminal have what appear to be fuse holder type devices on them, is that what the fusible link wire replaces? or is that whole wire trashed.
Post by: VileZambonie on April 23, 2009, 06:31:30 am
Maybe someone replaced your fusible links with inline fuses? You should put fusible links back in.
Post by: Captkaos on April 23, 2009, 11:13:38 am
Tech article was posted here now:
http://forum.73-87chevytrucks.com/smforum/index.php?topic=11972.0
Post by: roadrage41 on April 23, 2009, 03:17:43 pm
vile they were some sort of goofy y connectors, ive got it all patched up, it aint pretty, but its patched up. gonna get ahold of my buddy the car stereo guru and have him do some soldering for me.
