General Site Info => General Discussion => Topic started by: davlo on August 30, 2001, 10:03:00 pm
Title: 350 auto
Post by: davlo on August 30, 2001, 10:03:00 pm
have 84 silverado with 350 auto. It leaks from the speedometer cable and the vent in the center of the yoke. I drained it and changed the filter then removed the tail housing and replaced the gaskets , rear seal,speedometer cable and cleaned it up. refilled with proper amount of fluid but still leaks from the same places . what would keep the fluid that high in the tail housing???
Title: tranny leaks
Post by: j in la on November 06, 2001, 10:28:00 pm
i had the same problem with my tail housing.put some silicon in the little hole in the yoke.as for the sppedo cableif the orings are ok and everything tightens up i dont know what else to say without seeing it.how bad is the leak?
