73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: exilous on June 22, 2009, 09:40:46 pm
I'm getting down to the last few things that I might need to replace and may not and my harmonic balancer is one of them. I would assume its the original to the 78 engine, it needs a repair sleeve pretty bad but what I'm worried about is the rubber gaskets that are holding it together. They are pretty dry rotted and heavily cracked. Should I replace the whole balancer or should I just clean it up and put it on? and if I were to replace the whole balancer what kinds should I go with I have no idea what I would need to get. its a 350 4 bolt main. Thanks in advance.
I like these as a stock or mild performance upgrade
http://paceperformance.com/index.asp?PageAction=VIEWPROD&ProdID=6399
(http://paceperformance.com/images/products/manufacturer/GM/images/12555879.jpg)
Just get a replacement from autozone.
