73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: Mike Phillips on June 23, 2009, 07:40:25 pm
Title: BBC Power Steering Pump Brackets - Location and installation
Post by: Mike Phillips on June 23, 2009, 07:40:25 pm
Having a hard time figuring out how to bolt the brackets onto the power steering pump and then the engine in the right fashion.
Can someone with a  BBC maybe take  a picture of their pump and brackets on their engine and post it for me to use as a guide?
Title: Re: BBC Power Steering Pump Brackets - Location and installation
Post by: Captkaos on June 24, 2009, 05:44:33 pm
Mike,
The "outer" bracket goes to the waterpump, the L bent piece goes to the engine and wraps to the side of the engine.  If you post a pic I can tell you were it goes...  Are these the ones I sent you?
Post by: VileZambonie on June 24, 2009, 06:59:11 pm
It's not a close up but you can see how I just modified the stock bracket to work with the headers sorta.
(http://i6.photobucket.com/albums/y228/Sabaka454/DSC00277.jpg)
Post by: Mike Phillips on June 24, 2009, 07:44:39 pm
I think I have it scienced out.  I wasn't sure where the spacer and/or spacers go for the brackets.  Figured out one space that fits onto the front of the pump between the pump housing and the bracket and then seemed like there was a need for another one on the backside where the open hook portion of the bracket bolts to the stud coming out the back.
Will take a picture and post it and you guys can maybe tell if I did it right.
Thanks!
Post by: KoolerSL2 on June 25, 2009, 04:30:25 pm
r u installing this setup on a SBC?
if so heres a few pics of my setup.
had to use this setup since my heads dont have accy holes.
and i had to modify the back bracket and cut the arm off that goes to the motor mount hole.
plz excuse the cell phone pics.
click to enlarge.
(http://www.sixthsphere.com/storage2/images/plcc8y8emnvew134men_thumb.jpg) (http://www.sixthsphere.com/storage2/viewer.php?file=plcc8y8emnvew134men.jpg)
(http://www.sixthsphere.com/storage2/images/0hw4x1n84og6kki57a3z_thumb.jpg) (http://www.sixthsphere.com/storage2/viewer.php?file=0hw4x1n84og6kki57a3z.jpg)
(http://www.sixthsphere.com/storage2/images/5s2384e6avzlc4301_thumb.jpg) (http://www.sixthsphere.com/storage2/viewer.php?file=5s2384e6avzlc4301.jpg)
