73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => Topic started by: 82ChebySWB on July 06, 2009, 12:17:54 pm
Title: 2WD cracked steering box area/frame repair kit?
Post by: 82ChebySWB on July 06, 2009, 12:17:54 pm
Good afternoon guys, I've encountered the same issue that alot of 4WD trucks run into...thier frames crack right around the steering box area. My truck is an '82 1/2 ton SWB ...... the previous owner ran some 22's on this truck so I have no doubt that probably is the contributing factor to my current problem.
Does anyone know of a site or individual who sells a weld in frame repair kit for a 4WD?????
Some please post if you can help me out....
THANKS,
Brian
Title: Re: 2WD cracked steering box area/frame repair kit?
Post by: Captkaos on July 06, 2009, 12:39:00 pm
http://www.offroaddesign.com/catalog/steeringkit.htm
Post by: 82ChebySWB on July 06, 2009, 03:26:14 pm
On that page that kit is listed for a 4WD....though it does say this in the tech info area:
While the 2wd trucks use the same steering box bolt pattern, the frame contours are enough different that it can be a LOT of work to make the frame repair kit work.
Now there's this kit on Ebay:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=290324470313&viewitem=&sspagename=STRK%3AMEWAX%3AIT
I emailed the seller of that auction a couple weeks back and he did tell me that he has a "weld in" repair kit just like that auction...but it's a 2WD version like I need-----but it's $120 shipped because there's not as much demand for the kit. Question is though, looking at the pics...it appears as if both kits look the same........
So should I just grab one of these kits and hope for the best fit??? OR is there REALLY a 2WD kit available????
Post by: VileZambonie on July 06, 2009, 04:07:21 pm
Why not just trace the frame and make a template and cut your own piece?
Post by: Captkaos on July 06, 2009, 04:17:49 pm
Every frame rail on either 4x4 or 4x2 are identical.  That is why it is possible to convert a 4x4 to 4x2 and vice versa.
Not the best pic, but here is my 2WD frame
http://www.captkaoscustoms.com/images/beginfrtsuspr.jpg
Here is a 4x4 frame from CK5:
http://www.coloradok5.com/ordframebrace/P1010005.jpg
Post by: 82ChebySWB on July 06, 2009, 04:29:18 pm
Sure, that would easily take care of one side........but then how would you propose to take care of the other plate which has stamped contours to match the frame???
I'm not beyond fabrication.....but I'm not about to "hillbilly" something either.......
Thanks for the clarification Capt.  I greatly appreciate it.....
Post by: VileZambonie on July 06, 2009, 04:34:50 pm
Weld up the cracks and put the plate on the inside unless the thing is absolutely toast.
Post by: 82ChebySWB on July 06, 2009, 05:04:10 pm
To be honest, it's TOAST. I'd feel much safer when racing if I actually "sandwiched" the entire frame,welded the plates, and etc.
When I actually get to doing the repairs I'll post pics for yall......  I want to drive my truck BADLY....but I'm just scared to after my last outing.....  It's just not worth the gamble without fixing it.
Post by: Captkaos on July 06, 2009, 05:23:45 pm
The repair kit goes on the outside of the frame on both the steering side and the bottom of the frame.
Post by: VileZambonie on July 06, 2009, 08:36:24 pm
Just wrap some zip ties around it  ;D lol
Post by: SUX2BU99 on July 06, 2009, 08:59:09 pm
Duct tape, JB Weld and yer good to go. Git 'er dun.
Post by: 82ChebySWB on July 06, 2009, 09:04:02 pm
Yeah, I thought about using some JB Weld,super glue gel, and duct tape too.....but I doubt those would work for this particular application...... LMFAO.....
Post by: VileZambonie on July 06, 2009, 09:12:41 pm
My buddy came pulling into my work one day in his 77K10, turned into the parking lot and the steering box broke clean off the frame and he crashed into a huge planter, spilled a 5 gal pail of floor glue in his bed and ripped his wheel well out. He stuck a few chunks of metal between the frame and gear box and drove like that for 2 more years! lol
