73-87 Chevy _ GMC Trucks => Performance => Topic started by: Grover 1 on July 20, 2009, 07:30:31 am
I have a 1978 1/2 ton short wide pick up. It currently has a Goodwrench 350 and a turbo 350 transmission. I have a chance to pick up a period correct 454 and a 400 trans than are currently in a 78 pickup. The 454 was rebuilt about 60,000 miles ago and the 400 about 20,000 miles ago. I can get the whole truck for $1200.00. Is there a lot of other expense in swapping to a big block? I figured motor mounts, exhaust, perhaps a change in drive shaft length and maybe front springs would be about it. My 78 is a Big 10 so it already has the large radiator in it. Am I missing anything else of real importance? - thanks, Grover
If you have the whole truck it should be a piece of cake. Don't expect to get better gas mileage though... ;D
Motor mounts yes, there is a difference between the small-block and big-block mounts. Not too expensive though :)
(http://i633.photobucket.com/albums/uu59/Darknight455/Chevy%20Truck%20Stuff/SBvsBBMotorMounts2.jpg)
As long as the 454 donar truck is a true factory 454 rig everything should swap alright. Working on the same swap in my '77 Crew Cab minus the tranny part
Motor mounts do interchange between the two motors I have done it a couple times
I never had a problem
You need the gas pedal, kick down wiring and switch, fuel lines. get the whole truck! sell what you don't use
The gas pedal? Is there a difference in cable length? I'm swapping my 82 to a BBC. Thx
You need the gas pedal stuff to use the TH400. a TH350 uses a kickdown cable, but the TH400 does not. there's a switch mounted to the gas pedal bracket that controls downshifts alongside the vaccum modulator.
ooh nevermind, the kick down switch is not required for t400 is your using a full manual valvebody, I thought you talking about a different pedal assembly for a sbc to bbc swap.
