73-87 Chevy _ GMC Trucks => Interior & Equipment => Instrumentation => Topic started by: 76_Scottsdale on July 29, 2009, 06:17:45 pm
Title: SunPro tach super slow needle?
Post by: 76_Scottsdale on July 29, 2009, 06:17:45 pm
Hi all,
I installed a Sunpro Supertach a while ago and it has had the slowest needle I've ever seen on any tach. It's to the point where it doesn't even catch up to where the motor is revved. I have it hooked up the same as my last on to the negative side of the coil from my HEI distributor and the last one worked just fine. Any thoghts? Possibly a bad apple? I will contact Sunpro for possible warranty info.
Thanks
Title: Re: SunPro tach super slow needle?
Post by: Donut on July 30, 2009, 04:19:23 am
Has it always done this?  Double check all your connections.
I don't know what "a while ago" is for time (you did bump after 3 hours  :)), but I'd be looking at returning it if all my connections were good and installation is correct.
Post by: 78Scottsdale on August 09, 2009, 02:16:32 pm
I installed a SunPro Supertach II in my 87 Grand Prix, Did you make sure the little switch on the back of the tach is set to V8 instead of V6?
Post by: 76_Scottsdale on August 11, 2009, 01:09:43 am
Connections are good, switch is in v8 position, yes it has always done this from day one.
Post by: Donut on August 11, 2009, 04:43:37 am
That's why I mentioned returning it.  I've got a Sun pro water guage that's heading back, it reports my water temp @160 max.  It might be believable except for the 195 deg. thermostat.  Store slip says 90 day replacement if defective.
