73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: chronos on August 01, 2009, 06:13:52 pm
Thinking about picking this up, any opinions wold be great....thanks
406 small block chevy
I have a 76 400sb chevy bored .30 to 406 it has flat tops, balanced 55psi oil pressure has gear drive timing but i have a comp duel roller chain that was in it heads are shaved .10 with 202/160 valves comp cam with 292 duration not sure the lift but sounds good also comp cam roller rockers eldebrock intake and 750cfm carb and mini starter its a higher compression motor works great and it has about 3500km on it ran 160 to 170 degrees all day no heating issues motor was prof built 2000 obo.
I would ditch the timing gear set and go with the chain. So what kind of drivetrain is this going in front of?
Buddy SOLD the engine , I'm gonna have to keep looking !!
Thanks :D
