73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: jimbo on August 07, 2009, 10:50:38 pm
Title: Budget 8.5 10bolt posi/limited slip diff?
Post by: jimbo on August 07, 2009, 10:50:38 pm
I have an '85 silverado and am looking into stepping up the factory 2.73 ratio as well as adding a limited slip differential.  I just put 3.90's and a detroit truetrac diff in the '04 sierra, and while the truetrac is very impressive, it was hard on the wallet.  What more budget minded options do I have for the older truck?  I would really be interested in junkyard options.
Title: Re: Budget 8.5 10bolt posi/limited slip diff?
Post by: Captkaos on August 09, 2009, 10:57:36 pm
If you find a junkyard set that has the right gear and an open diff, you can add a drop in locker for about the same price as a new one but none of the setup cost.
Post by: jimbo on August 13, 2009, 08:58:27 am
Yeah, I just don't want to run a locker in this, as it is a work truck, especially with the 28spline axles.  I think I'm just going to keep my eye open for a complete rear with a slip in it.
Post by: Captkaos on August 13, 2009, 03:55:09 pm
it would be like finding a needle in a haystack to find a locker in a factory axle and for a 10bolt it will still be a locker as gov-locs are the only ones in a 10 bolt from the factory.
Post by: jimbo on August 13, 2009, 05:51:45 pm
Really?  I assumed there would be a few non gov loc limited slip rears out there with a steeper gear, that I could poach to set mine up.
Something like this:
http://dallas.craigslist.org/dal/pts/1316388962.html
Post by: Captkaos on August 13, 2009, 06:14:03 pm
No 10 bolt came from the factory with a Non gov-loc unless it was an open rearend.  The gov-loc IS a limited slip for the 10bolts.
Post by: jimbo on August 13, 2009, 06:43:38 pm
Oh ok, thanks.
