73-87 Chevy _ GMC Trucks => Wheels & Tires => Topic started by: gold84gmc on August 08, 2009, 08:19:39 pm
will rims from a f250 fit my 84 c2500?
Up to a certain year, 1997 or older. Sometime after that they changed some on the 8 lugs.
its kinda hard to tell in the pic i have of them but they look like theyre from a 2000's f250 but im not sure...the guy that has them used to have them on an 88 gmc 2500 so im 99% sure that theyll fit because the 2500 bolt pattern for gm was the same for a while (dont know the exact years) but the deal im getting is $60 for all 4 rims with 4 tires(only 2 have tread, mt 285/75/r16) and all 4 center caps so its a pretty good deal and theyre the aluminum rims
That is a deal if they'll fit and are straight.
If they are from a 2000's F250 they WILL NOT FIT your truck.
If this guy had them on a 88 GMC 2500, they didn't fit properly on his truck either. Ask him if the had the lug holes re-drilled and tapered...?
no theyre not modified at all....like i said its hard to tell from the pic i have (cell pic) and i dont know much about fords so i dont know when they changed the rims...thats why im guessing theyre from 2000's
Can you post the pic?
the first pic is the actual rims and the second one i think is the same style
Need better pics to tell. The second pic is definitely the '99-newer ford SD wheel, which will NOT work on your truck. I can't tell about the first pic.
All older 3/4-ton and 1-ton trucks (GM, Dodge, Ford) use the 8-on-6.5in bolt pattern, but the 1999-newer Fords are 8-on-170mm (~5 mm larger diameter than 6.5-inches). Pre-99 Fords have the same 8-on-6.5 that GM and Dodges use. Not sure why they changed... The wheels look very similar, and they will even fit over the studs if you push hard enough...
ok thanks for the info...ill try to find out what year theyre from and sorry about the pic
ok so the rims arent factory ford rims like i thought they were...theyre aftermarket but they have been on a chevy,dodge, and are now on a ford...i think theyre on a 87-91 f250..so now i know theyll fit my truck
