		73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: gold84gmc on August 18, 2009, 07:53:18 am
				whats the stock lift and duration for an 84 350
				Teensy and tiny.
				huh? lol
				I don't know specifically, but it will be around .414" lift and probably 220 duration.  It is a 3/4T truck so it was cammed to make low end power.
				is anything else different in the engine because i thought the only differences between a 1/2t and a 3/4t was the suspension,driveline,and gears
				81-86 only the 3/4T up and 1/2 4x4's got 350's along with 1/2 Burbs of any drivetrain config.  1/2T pickup 2WD only got 305's.
				Two cam options:
 .2484 in
 .2667 ex
 or the mighty
 .2600 in
 .2733 ex
 Duration was around 200/210
				^ Ick. I take it that's lobe lift and not valve lift? If that's valve lift.....wow.....double ick.
				That's definitely lobe lift. :D
