73-87 Chevy _ GMC Trucks => Body, Glass & Paint => Topic started by: Yeti_North on August 23, 2009, 07:14:42 pm
Title: Is there a replacement for the Rear cab mount floor rib section???
Post by: Yeti_North on August 23, 2009, 07:14:42 pm
I have 2 1980 c10 One a parts truck one a builder. Is there a replacement for the Rear cab mount floor rib section??? I have been searching but I cant find any info on it. I got 2 trucks for free one cab is done but the back is good the other truck cab is good but the rear cab mount brace is rusted out do they make a replacement for it? I only need one side driver side. as I said I do have a cab with a good one but I would rather replace with new if possible.
YeTI
Title: Re: Is there a replacement for the Rear cab mount floor rib section???
Post by: Captkaos on August 24, 2009, 06:03:07 pm
I am not sure what area you are talking about
Post by: joesgarage71 on August 24, 2009, 06:53:52 pm
 Post a pic of it!
Post by: Yeti_North on August 24, 2009, 09:13:28 pm
I will get a pic in the morning.
YeTI
Post by: Yeti_North on August 25, 2009, 09:03:20 pm
ok pix
http://i591.photobucket.com/albums/ss354/YeTI_north/Truck/100_1042.jpg
this is the rear cab mount
http://s591.photobucket.com/albums/ss354/YeTI_north/Truck/?action=view&current=100_1045.jpg
This is the rot.
http://s591.photobucket.com/albums/ss354/YeTI_north/Truck/?action=view&current=100_1043.jpg
This is where the rib run across the frame.
http://i591.photobucket.com/albums/ss354/YeTI_north/Truck/100_1046.jpg
the back section where the rib runs under the truck.
Does this help any??
YeTI
Post by: Marc on August 26, 2009, 06:44:48 am
If you make a template a sheet metal shop should be able to make one or two to slip on over it if all else fails.  Suprised it is so bad with the oil coating underneath and the rest of it looks good.
Post by: Captkaos on August 26, 2009, 05:24:39 pm
that piece is not produced, you are going to have to make something to fix it.
Post by: Yeti_North on August 26, 2009, 08:28:42 pm
Crap. Ok I will cut the one out of the other cab i have.
Tnx for the info.
YeTI
Post by: VileZambonie on August 27, 2009, 08:06:08 pm
Street sign post works good.
