73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: bk_cauley on September 13, 2009, 07:10:30 pm
does anyone know if i can use my fllexplate and convertor from my gen 1 motor, when i do my 5.3 swap. if not what balance, tooth count flywheel do i need to make it work. and can i use my convertor. does anyone know if the input shafts are the same.
I don't think you will be able to use the same flexplate. I know the ones are different for the two piece rear main seal and the one piece.
you have to buy a $50 spacer/adapter for it to work. im gona do the same whenever i get to do my 5.3 swap in my k10. ill do some digging and see if i can find a link for you.
here you go i found it!!
http://www.summitracing.com/parts/HUP-HP3795/
awesome. thanks man that is a mojor headache saver.
No problem
