73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: billywilly92 on September 20, 2009, 06:44:37 pm
Title: Swapping Gauges
Post by: billywilly92 on September 20, 2009, 06:44:37 pm
Right now I have a gauge cluster out of an 86 with the speedo and fuel. I have a gauges cluster out of an 81 or 82 I think with the speedo, tach, fuel, volt, oil, and water temp that I want to install instead. Now how do I make this swap work? I searched around on here and I know a bunch of you know how to do this.
Title: Re: Swapping Gauges
Post by: Captkaos on September 21, 2009, 06:25:30 pm
Verify all your pinouts on the harness plug, if they are incorrect swap them out and plug it in.  you will need the Tach harness or a wire going to the tach portion of the cap.
Post by: billywilly92 on September 22, 2009, 06:00:10 pm
What do you mean verify pinouts? Do I need to make sure that my gauges circuit matches the plug? Like all the ends on the plug match up to a plug on the gauges circuit?
I have the tach wires too and they plug right in where they are supposed to so that is taken care of.
Post by: Captkaos on September 23, 2009, 03:07:27 pm
Yes, all the pins in the plug have to match or you wont get any readings.  If you started with dummy lights most of them will have to be moved.
Post by: billywilly92 on September 23, 2009, 05:18:56 pm
Will buying a new circuit for my year of truck fix the problem?
Post by: Captkaos on September 24, 2009, 12:35:02 pm
the printed circuit on the cluster fix it so you don't have to verify/repin?  NO.
Post by: billywilly92 on September 24, 2009, 03:28:15 pm
Ok so it doesn't matter what circuit I have, I have to repin it no matter what? I haven't looked at mine yet but what if mine doesn't have enough pins or does that not happen?
Post by: Captkaos on September 24, 2009, 04:26:31 pm
It will have enough, but their location changed based on what cluster options you had.
Post by: billywilly92 on September 25, 2009, 05:49:30 pm
So how do I figure out which goes where? Is there a wiring diagram for the circuits and gauges from each year?
Post by: billywilly92 on September 27, 2009, 09:12:34 pm
Does anybody have or know where to get instrument cluster wiring diagrams?
Post by: Captkaos on September 28, 2009, 02:50:52 pm
In the technical section of this forum.
