73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: beastie_3 on October 10, 2009, 03:08:31 pm
Title: Which P/S pump do I have?
Post by: beastie_3 on October 10, 2009, 03:08:31 pm
How can I tell if I have a press fit, or keyway power steering pump? Its on a 1979 K10 V8. I couldnt find anything in the search.
Title: Re: Which P/S pump do I have?
Post by: zieg85 on October 10, 2009, 03:15:38 pm
Key-way type has a nut holding the pulley on, press fit doesn't and is flush with the pulley.
Post by: zieg85 on October 10, 2009, 03:26:42 pm
This pic is a Key-way type
Post by: zieg85 on October 10, 2009, 03:49:11 pm
Here is a picture of a press on type
Post by: beastie_3 on October 11, 2009, 02:01:44 am
OK, Ill take a look at my truck and check it out. I also read that there is also a metric version for 79+. Reason Im asking is because I might be interested in doing a March serpentine pulley conversion.
Post by: zieg85 on October 11, 2009, 08:24:35 am
Metric uses o-rings on the ends of the hoses.  Serpentine of newer style Chevy spins the waterpump opposite so you will need a waterpump and clutch fan off that setup if you go stock.
