(http://i955.photobucket.com/albums/ae31/jeffreyberry1/DSC00535-1.jpg)
Hi everyone ,
it has been a while since i last posted. But now Snow was flying here in NH. And my 89 Blazer is not ready for the winter. It needs some TlC . To be honest sometimes i am a little embarrassed because there are so many nice trucks you all own. And mine is a product of the rust belt of New England that i use for plowing and Home depot runs. I was not sure where to post because i will be doing several jobs. but all blazer specific so i put it here. let me know if this is ok. Along the way i will chart my progress for anyone interested and ask for help, because a lot of what i do mechanically is a new experience for me. Ok, here is a list of what i can think of right now of what i will be doing:
1) rear body mounts, near the tail pan. (I did the other body mounts last year.)
2) Frame needs repair in 2 spots. first, the holes are blown out by rust for the rear body mounts. second, where the receiver hitch was mounted to the frame has rust holes on each side probably covering a 3x6 area on each side of the frame.
3)Replace the 700r4 tranny currently in the truck. last spring i lost 3rd and overdrive. I bought a used 700r4 with 6000 miles on it to replace it. also i think i want to put a shift kit in the replacement tranny. I will definitely need advice on this.
4)change the rear end, shocks, and brakes.(i did the front last spring).
5) replace the rear main seal (leaking)
6) replace fuel lines and brake lines at the back of the truck. (they are so rusty).
7) apply some sort of rust inhibitor to the whole underside. (bar and chain oil?).
and that should do me for this season. lol!
Hey all,
thanks for the replys. i am going with a new sending unit for my tank . and fuel lines from the back half of the truck. what can i do to replace the stainless braided lines that connect to the sending unit? can't find anything specific for the job. I have chassis saver silver aluminum coming to paint my tank with.
Next i finally have some pictures of the damage to my blazer frame from rust. They are pretty ugly. i hope i can make a large improvement on the frame towards the tailpan. any ideas on how to tackle this will be greatly appreciated. you can see i have a "custom" tailpan that i installed last year. My plan is to replace the blown out area with new steel and weld a short piece of rigid tubing on the tailpan to accect the carrage bolts for the body mounts. what do you all think?
(http://i955.photobucket.com/albums/ae31/jeffreyberry1/IMG_0009.jpg)
(http://i955.photobucket.com/albums/ae31/jeffreyberry1/IMG_0006-1.jpg)
Next i have these holes on each side of the frame from rust forming between the frame and a trailer hitch.
also you cannot see the frame is deformed in this area from the awsome power of rust. i am planning on cutting patching and reinstalling the hitch. give me your ideas. I think the frame is intact enough that with repairs and cleaned up and protected it will be ok.
(http://i955.photobucket.com/albums/ae31/jeffreyberry1/IMG_0013.jpg)
(http://i955.photobucket.com/albums/ae31/jeffreyberry1/IMG_0014.jpg)
looking forward to you guys thoughts,
Jeff
hey here is an update on my blazer , I am into it deep. basically the frame is disassembled in the back i am cutting out all the deformed and badly rusted metal. which has been done already. i am sandblasting all the good remaining metal and will begin to put it back together. right now i am sandblasting.
also i am working on getting the old transmission out. to put in a working unit. this is new to me so it is going slow. Any tips on removing the tranny? Here is a recent pic. the chickens are no help at all!
(http://i955.photobucket.com/albums/ae31/jeffreyberry1/IMG_0100.jpg)
