73-87 Chevy _ GMC Trucks => Performance => Topic started by: StuntManMike on October 31, 2009, 03:28:40 am
Title: cheap good headers?
Post by: StuntManMike on October 31, 2009, 03:28:40 am
hi guys! i was wanted to get some opinions on some cheap headers for my 87 v10, i want to put some on but dont want to put a hole in my wallet. I went on summit racing and seen summit makes there own headers they also have some hedman and flowtec headers at a good price. I also found some hooker headers for decently cheap as well. anyone know if these opions are any good or have any suggestions? Im not looking at paying anymore than $120 for the set.
thanks guys,
Mike Felker
Title: Re: cheap good headers?
Post by: VileZambonie on October 31, 2009, 08:49:58 am
Personally I never use cheap non coated headers anymore because they rust in no time and they constantly leak. I've had good luck with some of the overseas cheapies. Is your 87 V10 a truck or blazer? 5.7 tbi? Do you have a.i.r. ? Are you looking for full length headers? Since your goal is to save $ Why do you want to run headers anyway? Do you have stock manifolds? Keep in mind you'll need an O2 sensor bung also.
Post by: 4x4orbust on October 31, 2009, 01:31:15 pm
i have a set of hedman headers that i like.   i would not cal them cheap, but they arent too pricey.   no leaks,  and they are rusted, but not so bad as to replace them.   my $.02
Post by: Chevalade on October 31, 2009, 06:00:53 pm
No such thing as a cheap good header. If you plan on keeping the truck for any length of time, get a good set. It will be worth it in the long run.
Post by: dunedigger on November 01, 2009, 01:11:42 am
Here in michigan it seems no mater what header I buy it will rust out if I drive in the salty winters.  But I've only tried headman and dynomax so far and I hated the headmans I bought.  I've been sticking with dynomax and had good luck except one pair had the tube bent too far in front of a bolt hole and I had to grind down a end wrench to tighten that header bolt.  I'll never buy another set that isn't coated.  It seems to be worth the extra money to save replacing them so often.  I did see somewhere a piece you can put between the header and collector with an o2 bung so you don't have to weld one in.  I've never put headers on a fi motor yet.
Post by: StuntManMike on November 03, 2009, 02:56:26 pm
sorry it been awhile and didnt reply but iv been moving. thanks for all your input guys! VileZambonie it is a truck and is a 5.7 and i am looking for full headers and i do have stock manifolds. i have heard alot about rusting...and in about 10 months im going back to pittsburgh so salt will be an issue...is there anything i can coat the headers in to reduce rust if i would go with headers?
Post by: Chevalade on November 03, 2009, 04:52:33 pm
You can buy headers already ceramic coated. I have a set on my 81, long tubes. Cost me about $450 or $500 for them. They last well.
Post by: VileZambonie on November 04, 2009, 07:50:06 pm
you can get coated ones for under $300 bucks
Post by: dunedigger on November 05, 2009, 07:39:44 pm
Yeah, not sure on price but I know my dynomax ceramic coat were less than 300
Post by: jimbo on December 03, 2009, 10:05:08 pm
How about these?
http://www.summitracing.com/parts/SUM-G9006/
Post by: lbrowne on December 28, 2009, 09:56:10 pm
How about these?
I was wondering the same thing. I've heard of people use the summit brand equipment with no issues which is usually just a re-branded product they carry. For example, those headers might actually be made by Pacesetter or Hedman.
Post by: joesgarage71 on December 29, 2009, 10:07:17 am
I always check the summit stuff first when making a buy. There parts are good quality and inexpensive. If there is any problem with them summitracing will back them up! Headers only last me about two-three years anyway so I buy them inexpensive.
BTW I Never use the words "cheap and good" together.
Post by: VileZambonie on December 29, 2009, 10:17:14 am
http://www.summitracing.com/parts.aspx?sku=BIG-31500FLT
http://www.summitracing.com/parts.aspx?sku=BIG-31506FLT
Post by: frogman68 on December 29, 2009, 12:54:47 pm
How about these?
Used them on a 84 k10 manual trans and no big issues.
Hard part was getting the pipe to the rear past the cross member but the 20 ton press fixed the pipe no leaks as of yet.
For the headers , pipping and mufflers was a little less than 200 dont expect it to last but its doing the job lol
Post by: 1badazz84 on December 30, 2009, 08:47:05 pm
I BOUGHT A SET FLOWTECH FOR $120.00 AT AUTO ZONE. I HAVE THEM FOR 5 MONTHS SOUNDS GOOD THEY HAVE NOT RUST BUT IM GOING TO USED HEADER WRAP FOR HEAT BUT THE DIFFENCE BETWEEN THE GOOD ONES & CHEAP ONES ARE THE DIFFERNCE GAUGE OF THE STEEL THEY USE.
Post by: lbrowne on December 30, 2009, 09:00:43 pm
Do yourself a favor and DO NOT use header wrap.
Post by: VileZambonie on December 30, 2009, 09:04:13 pm
Unless you are just running down the strip and rest I wouldn't recommend header wrap either
Post by: Josh454 on December 30, 2009, 09:38:13 pm
Flowtechs are some of the better ones out there for spark plug clearance too.
Post by: derrick79 on December 31, 2009, 12:54:49 pm
yeah summit doesn't have their own stuff, it is usually just all re-branded. i bought a set of summit headers for my 98 Z71 and when i got them, they were actually PaceSetter. Even the installation instructions were the PaceSetter instructions. however they were super cheap.
Post by: bobcooter on December 31, 2009, 08:43:36 pm
I bought a set of the Summit headers and used the copper gaskets on my 79- 350. They fit well and I haven't had any leaks yet ( about 7000 miles on them). I painted over them with VHT black before I installed them. All the paint went up in smoke in about the first 10 to 15 minutes though. The primer has lasted pretty well though. I bought a Summit brand cam once and when I got it it was a Crane cam.
Post by: bulldawg1081 on February 17, 2010, 12:04:40 pm
not trying to hi-jack the forum but what about a good set of shortie headers? do you gain any performance with them or just with the long tube type? i just want something i can install and not have to modify my exhaust but gain a little power
Post by: jimbo on February 18, 2010, 07:44:07 am
I had shorties on my last truck.  Although I didn't dyno it, there was a decent gain.  I used them mainly to ensure that the collectors didn't hang low.
Post by: 327power on March 15, 2010, 06:19:20 pm
Just bringing something up that was said earlier...whats wrong with header wrap?
Post by: beastie_3 on March 15, 2010, 07:32:23 pm
Voids the warranty and can distort the tubes, especially on thinner metal headers.
Post by: Captkaos on March 15, 2010, 09:47:43 pm
And it ends up rotting the tubes by holding moisture in.
Post by: 327power on March 16, 2010, 11:55:44 am
Oh...ok. Just wondering because they look cool sometimes.
Post by: liftedchevys87 on March 27, 2010, 11:01:56 am
I have the Summit $99 headers on a 78 chevy 454, they have been on there for 5 years with no problems ( I live in CT salty winters also )
Post by: Irish_Alley on March 28, 2010, 03:58:15 am
I once read that
"Cheap, fast, reliable you can only chose two" and for most things I find it true
