73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: bake315 on October 31, 2009, 01:57:42 pm
Title: camshaft removal problem
Post by: bake315 on October 31, 2009, 01:57:42 pm
OK, so I'm in the middle of upgrading my camshaft, and I'm having trouble removing the old one.  I can get it to come out about 4 inches, but no further.  Pushrods and lifters have all been removed.  I don't want to damage anything.  What did I miss?
Motor's in my sigline.
Thanks!
bake315
Title: Re: camshaft removal problem
Post by: bake315 on October 31, 2009, 02:04:26 pm
Whoops!  I think I just figured it out.  Gotta pull the fuel pump!
Post by: hotrod24 on October 31, 2009, 03:57:16 pm
dont forget the little rod that is in there
Post by: dunedigger on November 01, 2009, 01:14:56 am
I somehow knew what it was before I opened the thread, lol.  I've been there too.
Post by: bake315 on November 01, 2009, 10:24:37 am
Yep it came right on out once I pulled the pump and pushed the rod back.  Only now that I've pulled the cam, I discovered two other concerns.  The second from the last bearing has some fairly bad nicks in it.  Also, the second from the first slid out a good ways as I was pulling the cam out.  Obviously I'm going to want to replace both of these, and if I'm going to do them, I might as well do all of them.  Am I going to have to drop the crank in order to get the new bearings in?
Post by: dunedigger on November 01, 2009, 06:41:39 pm
The crank doesn't have to come out but you should should condider a full rebuild.  You will get metal shavings when installing the new ones.  If the cam bearings are bad it is likely the rods and mains are bad as well.
Post by: bake315 on November 01, 2009, 08:44:38 pm
Ugh...  I didn't really want to have to go there, yet.  Just out of morbid curiosity, if one didn't pull out the crank, how would one replace those bearings?  Through the front?  I could see pulling them all out that way, just not putting them back in.
Post by: Blazin on November 01, 2009, 09:37:57 pm
You will need a cam bearing removal / installation tool. They go in one after the other from the front.
Post by: VileZambonie on November 02, 2009, 04:53:27 am
You're gonna have to pull the engine to do it.
Post by: bake315 on November 02, 2009, 09:17:34 am
Yeah, that's what I'm thinking is going to happen.  I worry too much about damaging those bearings by pushing them through so many holes - seems it would weaken them too much.
Oh well...  Pulling the engine isn't so bad, I guess.  Here's a pic of how it sits now - I'm practically there already.
Post by: bake315 on November 02, 2009, 06:16:45 pm
OK, here are some shots of the cam.  I do this because I'd like some feedback about its state of wear, and possibly ID-ing it.
Post by: bake315 on November 02, 2009, 06:18:52 pm
And here are three more.  I see "GM 12" and "304" stamped on it.
