73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => The Highs (Raising/Lifts) => Topic started by: krafty33 on November 16, 2009, 08:56:05 am
Can you guys tell me what your vehicle height is after a six inch lift with 33 inch tires. I am looking at the height from the ground to the top of the cab. I just need to know if I will be able to get mine out of the gargage after the lift. I have a 76 K10 longbox
Wish I had a cab on mine to measure it for you, but I can tell you that I have a 4" lift and 33's and that is all I can fit in the garage with a standard size bay door. I have to hold the door up to get it in.
And if you have a 6" lift and 33's it is going to look dorky....you will want 35-44's with 6" of lift.
i know on my buddys blazer with 4" and 38's we had to air down the tires a good bit to make her fit
If your throwing on 33's you better go with a 4in lift. A 6 in would just look goofy with that tire size.
Here's a pic of my k10 with 6 in lift and the old 33's on her.
(http://img190.imageshack.us/img190/8315/img0469cy.jpg)
here she is with 35's and 6 in lift
(http://img34.imageshack.us/img34/2032/img0115pw.jpg)
Pictures are worth a thousand words
My 78 Blazer has a rough country 6" lift, 33" tires on 8" wide rims. It measures just under 7 ft from the ground to the top of the cab.
