73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => The Lows (Lowering/Drops) => Topic started by: kustom71 on November 26, 2009, 11:22:26 am
Title: ? about front drop
Post by: kustom71 on November 26, 2009, 11:22:26 am
HAPPY THANKSGIVING!
I have an 86 lwb c-10 and have already installed a bell tech flip kit
Mow Im about ready to do the front but im not sure how much of a drop I will need to get it even with the back
Will it need 3inch spindles only,or drop spindles and springs?
Is there anyway I can figure out what I will need?
And if it needs spindles and springs should I use the biggest drop spindle to keep steering correct or spilt the difference in spindle and spring?
Thanx
Title: Re: ? about front drop
Post by: VileZambonie on November 26, 2009, 02:42:26 pm
Take a tape measure and see how far you want the front to come down.
Post by: biscuit41 on November 26, 2009, 06:47:33 pm
Did you have some rake before?  The back is generally 2'' higher than the front in stock form.
Post by: kustom71 on November 26, 2009, 08:21:25 pm
Guess you can tell I got alot of things on my mind
I sat here all day thinking about it and never even thought of just taking the wheels off and lowering it on the jack while measuring
Thanx
Yes It did have a slight rake I will try measuring tomorrow
Thanx again!!!!!!!!!!!!
