73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: LUV2XCLR8 on December 04, 2009, 05:09:54 pm
Title: Can't find a HP PS Hose for my Blazer
Post by: LUV2XCLR8 on December 04, 2009, 05:09:54 pm
My 81 has a serp set-up, so does my 72, but I can't find
the line anywhere? Nothing I find looks like what I have?
Anybody have any ideas on what I can do? Thank you  :'(
Title: Re: Can't find a HP PS Hose for my Blazer
Post by: VileZambonie on December 04, 2009, 05:13:43 pm
Autozone?
Post by: LUV2XCLR8 on December 04, 2009, 05:21:34 pm
81 never came with serp set-up. I have spent hours
at numerous stores trying their patience and nothing.
I can't find anything that looks like what I have on it.
*A custom one made from Summit is around $70.00
Post by: HAULIN IT on December 04, 2009, 05:37:46 pm
Can you post a pic or Two of the engine, power steering pump, ect.? Maybe someone can Identify it. Is this a factory looking set-up on some year vehicle or A/M stuff? Lorne
Post by: LUV2XCLR8 on December 04, 2009, 05:45:43 pm
Aftermarket GM serp set-up on my 72 Blazer.
PS box fittings are the same on as on my 81.
Pump end we think is a 14mm x 1.5 w/ o-ring
Box end should be a 5/8-18 w/ out an o-ring
(http://i831.photobucket.com/albums/zz236/TNCTC/2wd%20Yenko%20C5/100_2587.jpg)
Post by: VileZambonie on December 04, 2009, 05:50:56 pm
http://www.autozone.com/autozone/catalog/parts/partsProduct.jsp?skuDescription=Duralast+/+Power+Steering+Pressure+Line+Hose&categoryDisplayName=Suspension+%26+Steering&fromString=&itemIdentifier=217059_0_11713_&productId=217059&sortType=null&parentId=46-0&filterByKeyWord=&isSearchByPartNumber=&navValue=14602103&categoryNValue=&fromWhere=null&itemId=2103-0&displayName=Power+Steering+Pressure+Line+Hose&store=5152&searchText=&brandName=Duralast
Post by: LUV2XCLR8 on December 04, 2009, 05:55:45 pm
Wowsers, you guys are quick on the fly using serches  :o
Do you think I can bend that straight end w/ out kinking it?
Nobody in my town has it for me to even test fit this  >:(
Post by: LUV2XCLR8 on December 06, 2009, 04:23:48 am
I found one, but it's o-ring on both ends, can it be modified?
Post by: Irish_Alley on December 06, 2009, 05:39:55 am
my 79 had the flange type and my 86 has the o ring type. i pulled the engine out of my 86 to put in my 79 ran into that problem then i just switch PS pumps and that was done. might be easer to go to the junk yard and grab a newer style
Post by: LUV2XCLR8 on December 06, 2009, 08:47:52 am
I thought of that, but everything is brand new  :'(
Post by: Irish_Alley on December 06, 2009, 09:57:01 am
you might be able to get someone to make one for you or combine the two
Post by: VileZambonie on December 06, 2009, 10:10:29 am
What exactly do you need?
Post by: zieg85 on December 06, 2009, 11:11:45 am
Take the fitting out of a newer pump that takes the 0-ring type and put it in yours.  I have done it many times.
Post by: LUV2XCLR8 on December 06, 2009, 04:28:33 pm
Are you talking about a Box fitting? Where can I get one of those?
Post by: zieg85 on December 06, 2009, 04:43:55 pm
I am talking about the hp fitting on the pump.  I think it takes a 1 inch wrench.  I can take pics tomorrow if you need them, I know I have pumps in my shed.
Post by: LUV2XCLR8 on December 06, 2009, 05:16:02 pm
The pump is not the issue, the box is. I found lines
for the pump, just not for the box itself. However,
I guess I could change it out and go that route  ;)
Post by: HAULIN IT on December 06, 2009, 06:33:03 pm
It sounds to me that you have a pre-'81 box & a post-'81 pump. You should be able to get a hose for the pre-'81 (flare seat ends) & change out the fitting on the back of the pump to a flare fitting as mentioned. Hope this helps, Lorne
Post by: LUV2XCLR8 on December 06, 2009, 06:42:13 pm
Exactly, but can you buy that fitting anywhere?
If so, what exactly do you  ask for?
This shouldn't be difficult  >:(
Post by: HAULIN IT on December 06, 2009, 08:48:35 pm
It would be the pressure side fitting on the pump...Maybe still available from GM? ANY pre-'81 pump has what your looking for, doesn't have to be a Chevy, truck, 350 or anything like that...a '72 Buick pump, a '77 Toranado, a '79 Chevy van, ect. ect. ect. Salvage yard trip? Now if your trying to get a chrome one or something, now your on your own. Hope this helps, Lorne
