73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => The Highs (Raising/Lifts) => Topic started by: bdnj on December 06, 2009, 09:31:00 am
Title: uneven lift 85 k10
Post by: bdnj on December 06, 2009, 09:31:00 am
hey,just bought this truck and im trying to right some wrongs.truck has a 4''suspension and 3''body lift.the guy left the front body mounts and put the new ones on top,not in the back though...should i just add mounts to the back or try and get the fronts out?i'm no mechanic but i've tooled around with jeeps and trucks a little,so im looking for the simplest remedy. if i try to pull the fronts'
 will i have to shorten the steering rod?it's about a 1 1/2" drop.......
Title: Re: uneven lift 85 k10
Post by: Irish_Alley on December 06, 2009, 10:00:53 am
there should be no rubber in the rear if thats what your talking about. but if you do touch the front your steering rod will shorten itself
Post by: VileZambonie on December 06, 2009, 10:05:54 am
Are you saying his body lift is comprised of the factory mounts with new mounts on top of them? Then what's under the bed?
Post by: bdnj on December 06, 2009, 10:12:49 am
3'' blocks all around,on top of rubber up front.it looks odd
Post by: VileZambonie on December 06, 2009, 10:14:56 am
That doesn't make sense. If the body lift was higher in the front the bed wouldn't line up with the cab.
Post by: bdnj on December 06, 2009, 10:41:18 am
gap between cab and bed is even too,i don't get it.
Post by: bdnj on December 06, 2009, 10:45:44 am
scrath that,its not even.doesnt look as off in person.i'll try and get some better pics
Post by: Donut on December 06, 2009, 11:50:30 am
To me, It looks like the nose needs to drop a little.  Body lines appear to line up (looking down the side) but the gap between the bed and the cab appears to be wider on the bottom.
Post by: VileZambonie on December 06, 2009, 12:02:16 pm
Take the body lift right out.
Post by: fitz on December 06, 2009, 01:12:26 pm
Good eye. I'm guessing part of the problem may be that the truck has new springs in the front and 25 year old springs in the rear.
Post by: Chevalade on December 06, 2009, 03:23:53 pm
Ditto.
Get some Zero Rates for the front (brings it up an 1") and a shackle flip or new springs for the rear.
Post by: bryco3 on December 06, 2009, 04:17:36 pm
To me it just looks like the truck was parked on a slope. Anyone else seeing this?  ???
Post by: bdnj on December 06, 2009, 05:19:42 pm
the four cab blocks were put on top of the old rubber ,im just gonna add to the bed ones.the sloped parking does'nt help the pic either...ok i'll stop yappin about it and just fix it...thanks guys
Post by: Irish_Alley on December 07, 2009, 12:32:05 am
maybe its just me but my 79 only has bushishing in the front and the bushing kit only came with bushings for the front the bed bolts right to the frame since the po put in a body lift thats all that goes in the rear and you use your bushings for the front. i don't see a problem but maybe its just me or I'm not seeing the whole picture
Post by: 78 Chevyrado on December 07, 2009, 06:30:10 pm
It looks ok....  Remember the front wheel opening is higher in the fender than the rear wheel opening.  May be an illusion.
If the truck actually sits level, you'll have a bigger gap in the front wheel well than in the rear wheel well.
Post by: Captkaos on December 07, 2009, 09:24:37 pm
Actually the rear would have a larger gap above the tires if it was lifted evenly.  The rear opening is shorter on the bottom side.
It looks like the front has new springs and it had a set of blocks removed from the rear.
Post by: bdnj on December 08, 2009, 03:19:50 pm
new rough country springs front and old springs wt blocks rear.its fairly new.someone else said old rear springs are the culprit.
Post by: fitz on December 08, 2009, 03:29:24 pm
78 Chevyrado is right on.
 It went crazy trying to get my 81 to sit level. I've posted before about how i tried 3 different sets of front springs before I settled on some custom made shackles to make it sit so it's level to the eve.
 I would start by replacing your rear springs. If you need to dial it in more you can play around with the rear block. Maybe you need a 6" block cut down to 5" to make it look right.
