73-87 Chevy _ GMC Trucks => Wheels & Tires => Topic started by: three8six on December 15, 2009, 01:53:09 am
Could anybody refer me to a 15x7 wheel that would fit this truck with 3 1/2 back spacing? or less? I am just wondering because the 17's I have off of a stock 96 impala SS are still hitting the lip of the LCA even after what I feel should have been plenty of cutting/grinding.
Well I would even really like to put some 15x10's on it? I mean anything that won't scrub, and will clear my LCA. Also if anybody has a pic of how much they took off their LCA if they could post it? Maybe I can cut more.....THX
Your 17's are hitting the LCA, dropped components have a problem with 15" rims I have never had a problem with anything larger. Can you ake a picture of where it is hitting and post it?
What components are you using for the drop?
I will take pics next time I'm at the shop. I only used McGaughy's Spindles. I will say though its rubbing the sides of the LCA on the inner lip of the rim. I had no problems with the caliper even though it is pretty close(I think even with all stock they are close to the rim though). Its really got me wild because other than that and exhaust my truck would be able to be driven daily.
That is all you have on the front is spindles, no springs? what amount of drop?
If possible, get a picture with the rim on and the interference.
I didn't measure because I went from a 3 inch drop spring to a spindle, you know just took everything apart once. I'd say their just 2.5 drop spindles just as any others...thats probably what it dropped the truck? I know it did sit a little lower with the 3 inch drop coils, but they were 2-3 years old, and had be driven on by very hard by myself.
I have no idea why you would have clearance problems with just spindles if you put the stock springs back in.
maybe putting the stock springs back in that changed the angle on the spindle so now the caliper or spindle is hitting?
huh?
I have 15x7 with over 4" of bs and don't have any problems I'm lowered with 3 djm spindles and 3" ground force coils
that is crazy man.....you think it'd be possible that the wrong coilk springs could create a clearance problem? I have the same 17's and still dont clear after quite a bit of grinding on my LCA.........
Can you not post pictures?
All the springs are going to do is make the truck lower. I have never had an issue related to springs. The spindles will cause you to have clearance problems.
Yes I can, I will try and make a point of it tomorrow, its just not fun getting underneath a lowered truck, you know?
when my truck had 3" spindles and 1" springs to 3" springs I had no spindle problem
Check your balljoints. Are you sure it scrapes on both right and left wheel? I had similar scraping once caused by balljoints on a non-lowered '79 Monte Carlo. There were no other symptoms of a bad balljoint.
I think it may be due to the backspacing of those wheels. I remember seeing them on another truck and thinking that they were 'sunk in' to the wheel wells quite a bit, meaning that they are probably positive offset wheels.
With proper offset 16"(or larger) wheels, you shouldn't have any clearance issues. And if your LCAs are already clearanced, 15"s might fit, as well.
Yea, well here's the pics, Im not clearing 17's with clearanced arms, so I know I can't fit 15's......
(http://i124.photobucket.com/albums/p2/JessicaLenay/Seans%20Trucks%20n%20SHit/1.jpg)
(http://i124.photobucket.com/albums/p2/JessicaLenay/Seans%20Trucks%20n%20SHit/2.jpg)
(http://i124.photobucket.com/albums/p2/JessicaLenay/Seans%20Trucks%20n%20SHit/4.jpg)
(http://i124.photobucket.com/albums/p2/JessicaLenay/Seans%20Trucks%20n%20SHit/5.jpg)
(http://i124.photobucket.com/albums/p2/JessicaLenay/Seans%20Trucks%20n%20SHit/6.jpg)
I dunno how much these help? I'm just bout to give up on it, and throw some 22's on it and paint it, and drive it. haha
You have to take into account the offset of the wheel. Just because it will fit the bolt pattern, doesn't mean it will fit the vehicle.
Wheel offset:(http://www.discounttiredirect.com/images/wheel.offset.gif)
the actual question here is why my truck doesnt clear the same wheels as capt's truck when we have our front ends lowered the same, and the same wheels....?
Except for picture number 1 which I can't tell. It looks like you are clearing. And based on the pictures you haven't removed "that" much metal from the control arm. I have had to cut the whole ridge back on some with 15" wheels and reinforce them.
My truck that currently has the Impala SS wheels isn't lowered, but the truck they were on was lowered, but it used LCA's and springs. They will fit with some trimming on ones with spindles though.
If you spin the wheel does it still rub now? I didn't read back, but how much drop do you have and how?? Spindles = who and how much, Springs = ?
100 percent stock springs so no drop there, and a McGaughy's 2.5 inch spindle. I couldnt tell you exactly how much drop I did get because when I put the spindles on I took out the drop springs and put in the stock ones. Thats good though I guess I'll keep cutting more off. I am close to clearing but when you have the wheel turned it doesn't clear. You can hear it hitting the back of the rim.
on my truck with 4.125 bs the the edge of the rim about meets the edge of the control arm with 3" djm and 3" ground force coils
(http://i147.photobucket.com/albums/r316/flamingc10/IMAG1773.jpg)
(http://i147.photobucket.com/albums/r316/flamingc10/IMAG1775.jpg)
what size wheels are those? Would a lowered srping give you additional clearance? I mean thinking of it in my head it would due to the lca being up closer to the bracket? Right?
there 15x7 I could tell any clearance changes when just had 1" drop springs
Once I can sell my wheels I was wanting to go to a 15x6 prolly in the front with 3 inches of backspacing, with a 15x10 in the back with 4inches or so of backspacing...
if your tucking tire you want 5" of bs
you're talking about on th 15x10's in the back correct?
yes
ok, sorry I was thinking for the front and was like nawww.... That'd look funny and put me in worse condition, I actually have been trying to contact people about narrowing the stock ralleys on the front for me, like for them to cut an inch out of the back of the wheel, so it'd give me clearance I need. I just don't like spacers.
Stockton wheels and Wheel Vintiques will narrow them. Should be able to find a wheel maker that will make them too, although finding some Van wheels (15x6) or base truck wheels (15x7) will be cheaper and easier.
I thought the stock 15x7 ralleye had the same backspace?
