73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: 305chevy c-10 on December 15, 2009, 07:11:29 pm
Title: 350 BLOCK (STROKER
Post by: 305chevy c-10 on December 15, 2009, 07:11:29 pm
WHO KNOW THE BASIC PARTS FOR A 350(383)STROKER is a 3.75 crank right and 5.7 rods
 is a 434 a 400 with a stroker kit and bored+.30over ....time for me to upgrade ........if someone can give me the details on what i need to build a 383 or 434 ......gonna try to get a pre85 350 or 400 block .....i know only one thing a stroker require a bigger crank with longer rods for a longer stroke .......im guessing.........i just want to build something with about 375-400 hp .....................thanks chevy fam
Title: Re: 350 BLOCK (STROKER
Post by: VileZambonie on December 15, 2009, 07:14:07 pm
Kinda hard to follow you there. The crankshaft determines the stroke not the rods.
Post by: eventhorizon66 on December 15, 2009, 08:19:29 pm
You can get 375-400 hp out of a 350, no problem.  If you build a 383 (4.030" bore x 3.75" stroke) and shoot for 375-400 hp you will have the same hp but with about 30-40 ft-lb of additional torque.  IMO building a 434 (4.155" bore x 4" stroke) and only shooting for 375-400 hp would be a waste of time and money, unless you need serious low end torque.
Post by: 305chevy c-10 on December 15, 2009, 10:22:21 pm
oh i see . :o.....i thought it was both rods and crank ...........see thats y i asked u guys . ;D.......so basicaly i can change the crank in a 350 and use stock rods in the 383 ..........thanks
