73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: Jim Rockford on December 31, 2009, 02:47:03 pm
Title: Little vid of the exhaust and a test drive....
Post by: Jim Rockford on December 31, 2009, 02:47:03 pm
http://www.youtube.com/watch?v=nG1kGrGx2Es
Title: Re: Little vid of the exhaust and a test drive....
Post by: CoggedBelt75 on December 31, 2009, 03:27:40 pm
Nice little drive. She sounded good and seemed to pass the test spin with flying colors. Thanks for letting us ride along.
Post by: Jim Rockford on January 02, 2010, 02:03:28 pm
well decent day at the junkyard, got a good set of drivers door hinges off a suburban , a couple of temp senders for my gauge, and all the chrome trim that goes around the grill, and found a brand new set of A/C delco wires on a 85 chevy truck that was a CFC victim and a good hood release cable. Also found a perfect bench seat out of a suburban  that I will use the covers and foam off of to fix mine.
Post by: team39763 on January 05, 2010, 01:43:49 pm
Sounds good.  What muffler did you use?
Post by: Jim Rockford on January 05, 2010, 09:32:13 pm
Muffler is a Pro flo  single in dual outlet, it was on the truck when I bought it..
 I swapped out my vac advance canister for a old one I had on another dist , that had a shorter stroke, so I didn't get so much initial vac advance,  reset the timing and this last tank was 14mpg up from 11MPG last tank and that was even some highway time and a tiny hole weeping gas out of the bottom of the tank. Picked up my core support and lower valance today from the guy and started installing that along with the surround molding I picked up from the junkyard..
Before..
(http://img.photobucket.com/albums/v189/ironroad9c1/1884%20GMC/IMG_1189.jpg)
(http://img.photobucket.com/albums/v189/ironroad9c1/1884%20GMC/IMG_1197.jpg)
After...
(http://img.photobucket.com/albums/v189/ironroad9c1/1884%20GMC/IMG_1437.jpg)
(http://img.photobucket.com/albums/v189/ironroad9c1/1884%20GMC/IMG_1438.jpg)
Got to pick up a headlight harness and then start on the bodywork.
