73-87 Chevy _ GMC Trucks => Wheels & Tires => Topic started by: hag77 on January 02, 2010, 07:20:47 pm
Title: wheel nut and stud problem
Post by: hag77 on January 02, 2010, 07:20:47 pm
went to take the wheels of my 82 1/2 ton 4x4 and the lug nut just spins and will not back off any tips on removing
Title: Re: wheel nut and stud problem
Post by: choptop on January 02, 2010, 09:37:59 pm
try to tightened it with an impact to see if it will grab any splines left in the lug, and then try to take it off with the impact. Is it on a steel wheel, or aluminum?
Post by: hag77 on January 03, 2010, 09:09:48 am
its a steel rim i will give that a try when it warms up i got about 5 that won't come off
Post by: bfofish on January 03, 2010, 09:24:25 am
Sounds like you might have the lugs that have the cheap chrome cover over a steel lug.
If this is the case you will have to rip the cover off and then you can loosen the lugs.
Post by: hag77 on January 03, 2010, 09:39:32 am
nope i got the open end type
Post by: Irish_Alley on January 04, 2010, 12:42:37 am
you could try to break it off, put a socket w/ extension or a 4 way then step on it till it breaks or give it a shot with a hammer but you might hit the rim with that
Post by: smitty77 on January 04, 2010, 04:14:49 pm
Suppose you could use a nut splitter as a last resort.....  I'd try the tighten-loosen trick first.
Post by: 4x4orbust on January 04, 2010, 04:35:25 pm
if all else fails,  and you suspect the stud to be stripped,   you could drill it out...
Post by: Irish_Alley on January 04, 2010, 04:47:35 pm
i know i said this before but you could take off all the lug nuts and drive it till the wheel falls off.  ::) j/k the nut breaker sounds like a good ideal. there was a nother form on here i forget what its subject was but they took a grinder i think to the wheel
Post by: Layne on January 04, 2010, 05:23:29 pm
http://forum.73-87chevytrucks.com/smforum/index.php?topic=14268.0
Post by: Irish_Alley on January 05, 2010, 12:36:35 am
thats it thanks layne
Post by: Layne on January 05, 2010, 04:59:09 pm
Good for a laugh, but I hope we don't have to get to that!
