73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: fighterofwars on January 02, 2010, 09:52:45 pm
Title: Truck Not running right.
Post by: fighterofwars on January 02, 2010, 09:52:45 pm
Okay, I bought a 1987 Chevrolet K20 with a 350 TBI this summer. The truck has 186,000 miles on it with many of the original parts. Well, the guy before me didn't drive it very much in the past 7 years and maybe a few times to the field to work. Well, it sat for awhile before I bought it. It used to run alright with no problems, but he said after it sat for awhile in his shed and he drove it out it took awhile for it to start. And when it did start the engine would speed up and slow down, speed up slow down.
Well, I bought it, put fresh gas in it, changed all the fluids, new thermostat, new air filter and its still doing it 3000 miles later. I thought it was just the old gas but it might have just improved a tab but hardly noticible since I first started driving. Also, if I try and drive it while its still cold the engine sounds like its not running on all cylinders halfway through the pedal, if I go about 3/4 of the way the engine really gets with it for like 2 seconds then starts doing it again. This happens in summer, winter, rain, or shine.
Sometimes it likes to idle really high. Like cruising speed high. I drove the truck 10 miles, shut it off. Went out a couple hours later and let it warm up. Started and ran back inside because it was around 13 degrees. Well I come back out and the truck is running pretty fast. So I get in and goose it a couple times. It stays the same. So I drive it home another 10 miles and it still is idleing way too high. So I shut it off, and start it back up and it idles at the right speed.
I already tried the TB gasket where I sprayed carb cleaner around the base and it didn't change the speed. I might try it again though just to make sure.
Sorry for the long winded post but I tried to give as much info as possible.
Title: Re: Truck Not running right.
Post by: jefferias on January 02, 2010, 09:57:26 pm
just a couple thoughts...
  fuel filter, dizzy cap/rotor, what do the plugs look like?, plug wires, is it throwing any codes on the dash?
Post by: fighterofwars on January 02, 2010, 10:01:21 pm
Where would the codes come up at? The only lights on the dash are the check engine light, 4wd light and Parking Brake light. The Check engine light is not on. But comes on when the truck is off but key is on so I know the bulbs not bad.
Post by: 4x4Cowgirl on January 02, 2010, 10:03:35 pm
The same thing happened to my boyfriend when he bought his 350 from this guy. He had the glass fuel filter on backwards to where it wasn't getting hardly any fuel and it caused the same problems you are having. You might check to see if it is on the right way. Just an idea.
Post by: jefferias on January 02, 2010, 10:07:18 pm
k your good im assuming if the check engine light is off--thats where you pull the codes if its on
Post by: fighterofwars on January 02, 2010, 10:08:37 pm
Yes, as soon as the truck starts the check engine light goes off.
Post by: Layne on January 03, 2010, 04:38:35 pm
Have you considered your Idle Air Control Valve?
Post by: Blue 82 on January 04, 2010, 05:58:12 pm
The IAC is most likely the culprit unless you have a major vacuum leak somewhere
should be ACDelco#  217-429   217-437
Your local auto parts store should have one for about $50
It should look something like this(http://i7.ebayimg.com/07/i/001/17/39/f746_3.JPG)
Post by: 78 Chevyrado on January 04, 2010, 06:07:34 pm
Here's the free and easy way to check your computer codes.  I used to do this on my 87 1/2 ton.
http://www.freeautomechanic.com/diagnostictroblecodes5.html (http://www.freeautomechanic.com/diagnostictroblecodes5.html)
Also, I'm don't remember the procedure, but there it a way to reset the IAC and I  have seen this help some people out.  just something to try before buying a new one.  Maybe somebodys know how to do it.
Post by: 1980c10 on January 04, 2010, 07:48:53 pm
you can cross two leads on your computer plug in(in the top corner can't remember what side). it will flash your check engine light 12,12,12,your trouble code(s) three times each and 12,12,12 when it is done and start again. your key must be on without the engine running. or you can use a scanner but isn't reeally needed. then google the codes. hope this helps.
Post by: Captkaos on January 04, 2010, 10:10:50 pm
top 2 right holes on the ALDL.
Post by: VileZambonie on January 05, 2010, 08:13:16 pm
If it's idle hunting all the time, cold start, warmed up etc then you most likely have a vacuum leak and yes the base gasket is a common failure
Post by: fighterofwars on January 26, 2010, 06:07:03 pm
Sorry for the long wait on the reply, I replaced the Fuel Filter, no change, put new cap and rotor on, no change, checked the TBI to Intake gasket and it didnt change when sprayed, we cleaned the Throttle body pretty good. But, I have gotten 3 codes now. One is Spark Timing, and Rich exhaust, and Lean exhaust. We checked the timing with timing light and it is spot on at idle.
Another thing, it seems like it doesn't have much power at crusing speed. For example, I'm driving along and I come to a very little hill, it suddenly feels like I let off the pedal and it shifts down, it does this at every hill and sometimes just driving on level ground it will slow down and down shift. And then sometimes it will slowly accelerate till about 70 all the while the pedal is in the same spot, of course this is just what I can tell, my foot might be moving a little bit and me not noticing it.
Post by: Layne on January 26, 2010, 06:35:01 pm
Sounds similar to my prob... Did you check your TPS and EGR solenoid? That was 90% of my dilemma
Post by: Lt.Del on January 26, 2010, 11:32:36 pm
Quote
try turning left
Post by: VileZambonie on January 26, 2010, 11:40:17 pm
Do you have a vacuum gauge or exhaust back pressure gauge?
Post by: beastie_3 on January 26, 2010, 11:47:10 pm
Quote
try turning left
Run left, not turn left. Duh.
Post by: Lt.Del on January 27, 2010, 11:35:51 am
Quote
Hey, it was my joke and I said, and say, 'turn left'. Duh!!
Post by: beastie_3 on January 29, 2010, 02:55:20 pm
But I corrected it!
Post by: fighterofwars on January 29, 2010, 07:06:23 pm
Quote
try turning left
Funny, Funny.
On a more serious note, I replaced the O2 sensor in the exhaust manifold on drivers side, New cap, rotor, plugs, and wires and still little to no improvement, The EGR valve still moves in and out when the engine is reved.
I thougth that the Cat might be plugged up with carbon, since and the guy that had it before me drove real slow all the time and so do I so that could cause it to plug up, since the longest distance I travel is 8 miles going 55, no hi-speed interstate driving. Would removing the CAT permanetly cause any problems with the engine running or anything, for off-road use only.
Post by: Layne on January 29, 2010, 07:35:55 pm
Gut That SUCKA!!! Don't drive her on the street tho, or at least don't get pulled over! ;)
You won't have any problems with it, as the O2 sensor is before the cat and nothing meters the flow after it. You motor will breath better. The only downside is increased pollutants coming out your tailpipe.
Post by: Irish_Alley on January 30, 2010, 01:23:19 am
a clogged cat will rob you of power but i thought they only do that once it get warmed up. a couple things to think of first check the fuel pressure and also try unplugging a sensor at a time and see if it hurts the idle, if no change it may be a problem. also for vile and them would a bad ground cause this problem?
Post by: VileZambonie on January 30, 2010, 07:15:14 am
A restricted exhaust can cause a no start. If you can throw a vacuum gauge on it or a back pressure gauge in the O2 bung that will tell very quickly if you have restricted exhaust.
Check your fuel pressure, if you don't have a gauge, pinch the return line and test drive it.
Post by: fighterofwars on February 21, 2010, 01:41:54 pm
Well, we put a new fuel pump in and that fixed it. Thanks for all the advice.
Post by: beastie_3 on February 21, 2010, 03:50:25 pm
Glad you found the problem!
