General Site Info => General Discussion => Topic started by: gold84gmc on January 04, 2010, 09:32:09 am
Title: is this diesel worth trading for?
Post by: gold84gmc on January 04, 2010, 09:32:09 am
i have been talking to a guy that has a 93 gmc 4x4 6.2 diesel, all it needs for a sticker is a water pump (he already has a new one) and the donut gasket leaks. it has a 4" magnaflow exhaust, new brake and fuel lines, new gas tank and sending unit, and he repaired the rockers...it has 150,000 miles and the injection pump was changed 20,000 miles ago and he said it runs and drives great...i wanted to know if you guys think it would be worth trading my truck for....ill try to post pics when he sends me some
Title: Re: is this diesel worth trading for?
Post by: Captkaos on January 04, 2010, 11:06:06 am
depends on what it looks like and what you want.
Post by: gold84gmc on January 04, 2010, 01:46:07 pm
well ive never had a diesel before and i didnt know if there are any problems with the 6.2 and if theres anything i should look out for before i trade
Post by: Captkaos on January 04, 2010, 02:17:39 pm
Generally speaking if it is running it should be fine.  After 1987 the major problems with them were fixed.
Post by: gold84gmc on January 04, 2010, 02:44:25 pm
alright thanks...so you think it would be worth trading?
Post by: Donut on January 04, 2010, 03:09:20 pm
Same as with any truck up here.  Check frame, brake lines, cab corners, rockers, floor boards, etc.  Before I decided to fix my truck, I had looked for vehicles up to late 90's, a bunch were as bad or worse than my '73.  Don't forget, there is a reason he wants to get rid of his truck.
Post by: gold84gmc on January 04, 2010, 04:28:50 pm
ya ill deffinetly check that stuff. he just changed the brake lines, fuel tank and sending unit, so i dont have to worry about those...he told me he has 3 diesels and he doesnt use this one anymore so he wants to sell/trade it, and he wants to trade for my truck because he wants to rebuild his 78 gmc...so if we trade ill be keeping the engine in my truck and rebuild it with the engine parts i already have, then sell the engine for a profit...probably be able to get atleasst $500 for it
Post by: gold84gmc on January 05, 2010, 01:53:42 pm
are the crankshafts weak in these engines? because ive heard that they easily break or crack if you rev it up when its cold
Post by: Captkaos on January 05, 2010, 03:59:31 pm
No, it is generally cause by worn dampners on old engines.  It is said the 88-93 versions updated.
Post by: gold84gmc on January 05, 2010, 05:23:23 pm
alright good...are these diesels fast like the the newer diesels (duramax,cummins,powerstroke)?
Post by: Captkaos on January 05, 2010, 05:50:20 pm
DEFINITELY not.  they were for MPG's not power.  The Duramax was designed to compete with the Powerstroke/Cummins.
Post by: gold84gmc on January 05, 2010, 05:57:00 pm
so does that mean that theyre slow or that theyre just not as fast as duramax
Post by: Captkaos on January 05, 2010, 06:12:55 pm
The 93 6.2L puts out 143 hp / 257 lb·ft.  This will have less power than a 93 350 Gas motor with 210hp.  But gas mileage will be higher.
Post by: werewolfx13 on January 05, 2010, 07:07:32 pm
Much higher mileage, my father in law is a mechanic at a lime and rock plant owned by certainteed, he LOVES the 6.2/6.5 diesel, mainly because of its mileage and long term reliability. He has an '89 with a 6.2 and 700r4 that gets mid-upper 20's mpg with 250k+ miles, and a 96? i think with a 6.5 that does a little worse mileage wise, but has a load more power. Course, he also has very little appreciation for any cummins short of the qsk 19-700. He also likes the power output of the powerstroke in the 1 ton ford van they have, but he hates the reliability or lack there of, as he usually puts it. Hes real impressed with the volkswagen jetta TDI they just bought awhile back..I was real impressed with it when i got to ride in it. 50+ mpg at 80+ mph.
Post by: gold84gmc on January 05, 2010, 07:48:21 pm
ya its a 92 not 93...sorry i thought it was a 93, i think for performance wise from best to worst it goes duramax,cummins, then powerstroke and from sound i think it goes cummins,duramax,powerstroke....ford has to put twin turbos on their engines while duramax and cummins only have one and powerstoke still has less power then duramax and cummins....i would love to have an 06 gmc 2500hd 6.6L duramax with the allison tranny
Post by: gold84gmc on January 06, 2010, 03:49:57 pm
so i went and looked at the truck today...it starts and runs fine, sounds good, probably the worst part is the passengers rocker panel, its not bad so i can put bondo on it and call it good but the problem is that this weekend is going to be about 0 degrees so itd be kinda hard to to that especially when i dont have heat in our garage. if i trade it would be this weekend that way i could fix the stuff over the weekend and get it stickered and registrated on monday...it needs the water pump but a new one is included, so i was wondering if you guys think i should trade
Post by: Captkaos on January 06, 2010, 05:11:12 pm
If your runs and doesn't need work, I say no.  But I am not sure why you are wanting to trade yet.  To get a 4x4?
Oh, and are you getting cash in addition on this trade?  What do you mean by "stickered"
Post by: gold84gmc on January 06, 2010, 05:52:31 pm
i want to trade because i want 4x4 and its newer, better on gas, and just because its a diesel...because i have always wanted a diesel, my truck runs but it can use some work, a little bit of body work and some other stuff...no im not getting any cash in the trade and i mean stickered as in inspection sticker
Post by: Captkaos on January 06, 2010, 05:54:51 pm
Safety inspection?
I would say if it looks like something you want and it has want you desire.  I would get it.
With a diesel you can expect about 22mpgs on the city even on the 4x4.
Post by: Jim Rockford on January 06, 2010, 06:34:30 pm
He better unload that really quick, VW is having alot of problems with the fuel systems in those cars and its a ton of money to fix em and VW isn't covering it under warrenties.
http://forums.tdiclub.com/showthread.php?t=268190
http://forums.tdiclub.com/showthread.php?t=268201
http://forums.tdiclub.com/showthread.php?t=268198
Post by: gold84gmc on January 06, 2010, 06:50:55 pm
it pretty much is what im looking for...i would rather have a duramax but its gonna be a long time before i get one of those and i just want to make sure itd be worth it because this is going to be my daily driver
Post by: Captkaos on January 07, 2010, 01:33:09 pm
If it has been taken care of I think you will like it.
Post by: gold84gmc on January 07, 2010, 02:57:22 pm
i dont know about the previous owner but this guy that has it now didnt abuse it because he doesnt even use it (he has 3 other diesels)...and the engine was changed and it only has about 126k miles which is nothing for a diesel
Post by: gold84gmc on January 08, 2010, 05:07:44 pm
so i did the trade and the guy brought the truck over today....here are some pics
Post by: gold84gmc on January 08, 2010, 05:08:32 pm
are diesels 12 volt or 24 volt?
Post by: Layne on January 08, 2010, 05:16:05 pm
Generally 24 v. Truck looks good! How many batteries does it have?
Post by: gold84gmc on January 08, 2010, 05:31:50 pm
it has 2 just like every other diesel so thats why i was wondering if it was 12 or 24 volt
Post by: Layne on January 08, 2010, 05:39:37 pm
I'm almost 100% it's a 24
Post by: Captkaos on January 08, 2010, 06:17:55 pm
It is 12Volt.  Only Military trucks were 24V.
Post by: Torque454 on January 08, 2010, 06:33:21 pm
Yep, 12v system. As mentioned, 24v was only for military trucks. There are two batteries but due to the way they are connected (pos to pos, neg to neg), they boost the amps and leave the voltage the same.
But, if they were wired where one pos was connected to the other neg, and then the other pos to starter and the other neg to ground, then it would be 24V with the same amount of amps.
Say two 900 amp batteries were wired together pos to neg for 24 volts, they would put out 900 amps at 24v where as two 900 amp batteries wired pos to pos and neg to neg would put out 1800 amps at 12v.
Post by: Layne on January 08, 2010, 06:40:49 pm
Huh. That's pretty interesting. Thanks for the info!
Post by: gold84gmc on January 08, 2010, 06:47:04 pm
ok thanks...and what about the gas? the owners manual says to push it to the floor and let go before you start it
